WALTn4149h
#1 Posted : Tuesday, October 14, 2008 6:41:13 PM(UTC)
WALTn4149h
How do you replace spray arm part #AP2039850 GE ? Item #501 on parts diagram.
#2 Posted : Tuesday, October 14, 2008 7:21:16 PM(UTC)
There are two tabs on the bottom of the cylinder. Pull them out on the old spray arm and pull the spray arm up. Push the new spray arm down until it clicks.
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Kitchen Aid Dishwasher Upper Spray Arm (Dishwasher Repair)
by Guest 1/13/2022 12:58:02 PM(UTC)
whirlpool du850swpb2 spray arm (Dishwasher Repair)
by willyw 12/22/2021 12:31:52 PM(UTC)
Bosch 300 dishwasher - Middle spray arm only active for half-loads??? (Dishwasher Repair)
by Xcessiv 12/9/2020 5:58:19 AM(UTC)
Dishwasher Spray Arms Not Spinning / Not Enough Water [SOLVED] (Dishwasher Repair)
by MontyTWD 10/5/2020 8:05:23 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Upper Spray Arms Not Spinning (Dishwasher Repair)
by navagator 8/24/2019 11:58:55 PM(UTC)
Bosch/Gaggeneau Low pressure from spray arms - tried everything (Dishwasher Repair)
by fixitboy 7/27/2019 10:50:29 PM(UTC)
Bosch dishwasher upper spray arm lost O-rings (Dishwasher Repair)
by Daniel J 2/10/2019 11:56:46 AM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 9:28:24 AM(UTC)
upper spray arm screw broken (Dishwasher Repair)
by peabody 11/30/2016 10:47:12 AM(UTC)
Spray Arm Doesn't Turn - Probe Misaligned? (Dishwasher Repair)
by amc2012 4/15/2016 10:17:31 PM(UTC)
Center spray arm not spinning (Dishwasher Repair)
by Moleski 1/26/2016 9:28:31 AM(UTC)
Water Supply Tube & Spray arm dangling (Dishwasher Repair)
by yinger 9/13/2015 11:10:13 AM(UTC)
No pressure in spray arms (Dishwasher Repair)
by Doop007 9/4/2015 7:21:56 AM(UTC)
