have a modern maid brand oven and range. It is a propane gas model. Can't find the model number anywhere. The oven takes up to 5 minutes before it will light. The igniter glows a bright red as soon as it is turned on. Any suggestions on why it is taking so long?
Sounds like either the ignitor isn't getting hot enough or the vavle isn't opening like it's supposed to. Look for the model number uner the top burners or in the storage drawer/broiler on the side wall of the range itself. Nat
