mcdboy
#1 Posted : Monday, August 25, 2008 1:12:53 PM(UTC)
mcdboy
have a modern maid brand oven and range. It is a propane gas model. Can't find the model number anywhere. The oven takes up to 5 minutes before it will light. The igniter glows a bright red as soon as it is turned on. Any suggestions on why it is taking so long?
libertyappl
#2 Posted : Monday, August 25, 2008 1:16:59 PM(UTC)
libertyappl
Sounds like either the ignitor isn't getting hot enough or the vavle isn't opening like it's supposed to.
Look for the model number uner the top burners or in the storage drawer/broiler on the side wall of the range itself.
Nat
Crosley Gas Oven igniter? (Oven Repair (including Ranges and Cooktops))
by gospelguy 1/18/2018 1:02:51 PM(UTC)
Confused about replacing oven igniter Frigidaire (Oven Repair (including Ranges and Cooktops))
by artemis 12/4/2017 9:24:14 AM(UTC)
Oven Igniter will not activate (Oven Repair (including Ranges and Cooktops))
by MDThompson 12/27/2016 4:05:57 PM(UTC)
Oven Igniter for Capri (Sears) Propane Stove (Oven Repair (including Ranges and Cooktops))
by BumpyKnuckles 11/26/2016 6:38:15 PM(UTC)
is the oven igniter supposed to go out after oven lights? (Oven Repair (including Ranges and Cooktops))
by dterrasi 12/6/2014 1:54:14 PM(UTC)
Oven igniter glows red but does not heat (Oven Repair (including Ranges and Cooktops))
by TeamCeisel 9/25/2012 4:21:07 PM(UTC)
Oven igniter Magic Chef (Oven Repair (including Ranges and Cooktops))
by Mar4130 8/14/2012 9:26:19 AM(UTC)
Bosch oven igniter repair (Oven Repair (including Ranges and Cooktops))
by soonerhokie 9/4/2011 11:27:12 AM(UTC)
Replaced Oven Igniter Melted Wire Nut (Oven Repair (including Ranges and Cooktops))
by Edward A 6/7/2011 3:44:07 PM(UTC)
oven igniter on, no heat (Oven Repair (including Ranges and Cooktops))
by alelessbee 4/28/2011 8:47:52 AM(UTC)
GE Oven Igniter coil replacement (Oven Repair (including Ranges and Cooktops))
by jeffcorona 1/6/2011 9:35:05 AM(UTC)
How do I replace the oven igniter on a GE XL44 Range? (Oven Repair (including Ranges and Cooktops))
by rwbarrett 12/20/2010 8:47:55 AM(UTC)
Oven Igniter (Oven Repair (including Ranges and Cooktops))
by LCPierce 12/9/2010 8:42:47 AM(UTC)
Tappan oven igniter installation (Oven Repair (including Ranges and Cooktops))
by Just George 11/24/2010 9:44:06 AM(UTC)
Replace gas oven igniter (Oven Repair (including Ranges and Cooktops))
by JRhein 11/15/2010 7:07:22 AM(UTC)
