Randy Toohill
#1 Posted : Saturday, August 16, 2008 3:08:36 PM(UTC)
Randy Toohill
Oven stopped working. Surface burners work fine. When bake,broil or clean button pushed, lock light flashes. When door locked and clean button pushed, it tries to start but stops and flashes F9 which means latch/lock. Checked it out and seems fine. Any help would be appreciated. Randy
Randy Toohill
#2 Posted : Saturday, August 16, 2008 5:23:45 PM(UTC)
Randy Toohill
Just checked lock switch and its fine. Would problem be in clock/control panel?
#3 Posted : Saturday, August 16, 2008 7:26:00 PM(UTC)
Randy,
If there is nothing wrong with the latch switches and/or wiring harness from the latch to the control board then the control board (aka clock) is probably guilty.
In order to provide the right part number for the clock I need the color of it.
Here are the break down diagrams for the Maytag range Model MER5750BAW
Whirpool Double Oven Stopped Working (Oven Repair (including Ranges and Cooktops))
by billpa 12/26/2016 3:26:42 PM(UTC)
Our Microwave Oven stopped working (Microwave Repair)
by Artista 12/26/2016 8:32:57 AM(UTC)
Thermador oven stopped working (Oven Repair (including Ranges and Cooktops))
by ajappliance 8/15/2016 8:17:57 AM(UTC)
Help wall oven stopped working (Oven Repair (including Ranges and Cooktops))
by pbcjbn 7/24/2015 2:09:41 PM(UTC)
Kitchenaid Gas Oven Stopped Working (Oven Repair (including Ranges and Cooktops))
by blair604 6/29/2015 3:58:57 PM(UTC)
Jenn-Air Electric Range - Oven stopped working (Oven Repair (including Ranges and Cooktops))
by johndbro1 6/20/2014 11:35:32 AM(UTC)
Whirlpool oven stopped working (Oven Repair (including Ranges and Cooktops))
by Branchminnow 11/7/2013 9:14:07 AM(UTC)
Thermador lower oven stopped working (Oven Repair (including Ranges and Cooktops))
by rattus 8/20/2013 9:13:47 AM(UTC)
Oven stopped working. (Oven Repair (including Ranges and Cooktops))
by T. Greeley 5/11/2013 4:41:39 AM(UTC)
Whirpool 465 gas oven stopped working (Oven Repair (including Ranges and Cooktops))
by cook-n-baker 2/10/2012 6:22:22 AM(UTC)
Oven stopped working shortly after SELF CLEAN (Oven Repair (including Ranges and Cooktops))
by zygis 10/19/2011 6:14:28 AM(UTC)
Fridgidaire Oven Stopped Working (Oven Repair (including Ranges and Cooktops))
by chemist308 9/17/2011 6:10:00 AM(UTC)
GE oven stopped working (Oven Repair (including Ranges and Cooktops))
by levendel 9/2/2011 5:02:55 PM(UTC)
GE Oven Stopped Working (Oven Repair (including Ranges and Cooktops))
by spc1102 7/4/2011 9:57:32 AM(UTC)
Kenmore Oven Stopped working (Oven Repair (including Ranges and Cooktops))
by badassbob 1/8/2011 4:26:29 PM(UTC)
