T. Greeley
#1 Posted : Saturday, May 11, 2013 4:41:39 AM(UTC)
T. Greeley
This morning, while cooking something in the oven, we heard a loud bang and the oven stopped working. There is no power to the oven/stove at all. We checked the circuit breaker and it was fine.
#2 Posted : Saturday, May 11, 2013 6:11:54 AM(UTC)
Parts for Frigidaire FEFL78CBC Range - AppliancePartsPros.com
Here is the wiring diagram
http://manuals.frigidaire.com/p...pringfield/316255355.pdf
Since stove is totally dead the problem is probably power related.
How did you check the circuit breaker?
Just looking at it is not good enough.
Also before doing anything try to find out what the bang was.
Remove power from the unit and check the bake and broil elements for a blow out.
Remove the back and check the wiring .
Try flipping the breaker off/on slowly a couple times, sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
[COLOR="Red"]Be careful as 240 volts is lethal !!! [/COLOR]
T. Greeley
#3 Posted : Saturday, May 11, 2013 12:23:25 PM(UTC)
T. Greeley
Upon removal of the back panel and inspection it appears the ceramic socket for the light was burned. The bulb however, still works. I removed the connector to the ceramic socket, exercised the breaker, and plugged the stove back in, but nothing came on. Could the light socket cause the whole stove to be inoperable?
#4 Posted : Sunday, May 12, 2013 4:32:35 AM(UTC)
[COLOR="Blue"]Could the light socket cause the whole stove to be inoperable?[/COLOR]
I doubt it.
Here is why I think it is a power problem.
If you look at the wiring diagram you will see that the stove top elements and the oven control and it's elements are separate entities.
The stove top elements require 240 volts (L1 to L2)
Their surface indicator lights require 120 volts (L1 to Neutral)
Since each one has it own analogue control (infinite switch), it is unlikely that they would all go out unless you have a burned off wire in the unit or there is a problem with power getting into the unit.
On the oven side the elements again require 240 volts.
But the control board runs off of 120 volts, again L1 to Neutral..
The oven light also runs off of 120 (L1 to Neutral).
I am a bit confused as you said " The bulb however, still works." but originally said nothing works.
Did you check this bulb outside the unit?
So if I understand your original post correctly that nothing works then my guess would be that you have lost L1 voltage as it effects all devices in the unit.
T. Greeley
#5 Posted : Sunday, May 12, 2013 8:00:43 PM(UTC)
T. Greeley
Yes, we tried the bulb outside the unit.
#6 Posted : Monday, May 13, 2013 1:47:10 AM(UTC)
Then I would do the procedure outlined in my first post.
T. Greeley
#7 Posted : Monday, May 13, 2013 12:04:57 PM(UTC)
T. Greeley
We checked the power at the wall outlet and at the terminal strip. Both are good.
#8 Posted : Tuesday, May 14, 2013 2:10:05 AM(UTC)
Since you have 240 at the termonl strip there must be a problem with a wire that is common to both the stove top elements and the bake elements.
