Oven stopped working. Surface burners work fine. When bake,broil or clean button pushed, lock light flashes. When door locked and clean button pushed, it tries to start but stops and flashes F9 which means latch/lock. Checked it out and seems fine. Any help would be appreciated. Randy
Just checked lock switch and its fine. Would problem be in clock/control panel?
Randy, If there is nothing wrong with the latch switches and/or wiring harness from the latch to the control board then the control board (aka clock) is probably guilty. In order to provide the right part number for the clock I need the color of it. Here are the break down diagrams for the Maytag range Model MER5750BAWGene.
