jorgey64
#1 Posted : 15 years ago
jorgey64
those the selenoid cause for the motor not to spin? i got a problem with the ice maker in my whirlpool ed25pqxfw02 it doesnt dispense ice the auger wont spin :(
#2 Posted : 15 years ago
Remove the ice container and the auger motor bracket. Tape in the door light switch. Push and hold the ice cube lever on the dispenser and check for 120 VAC at the auger motor terminals and the solenoid terminals for both cubed and crushed ice options. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED25PQXFW02 | AppliancePartsPros.com
jorgey64
#3 Posted : 15 years ago
jorgey64
i follow instructions i tape the door light switch test the auger motor for 120vac and the selenoid i didnt get no vac at all but the light turn on just fine
#4 Posted : 15 years ago
You did not say if you pushed the ice cubes release lever while doing that test.
jorgey64
#5 Posted : 15 years ago
jorgey64
i push the lever and switch from ice dispenser to crusher
#6 Posted : 15 years ago
Sounds like the problem is a bad pushbutton switch on the dispenser (#18 on the diagram).
- The pushbutton switch Part number: AP3132885
File Attachment(s):
Ice and water dispenser.doc (435kb) downloaded 4 time(s).
jorgey64
#7 Posted : 15 years ago
jorgey64
how do i remove the overlay front cover ?
#8 Posted : 15 years ago
The overlay is self adhesive. You have to be very careful not to damage it because the white overlay is no longer available. Only almond one is still available.
- The overlay Part number: AP3046851
Ice Maker Problems - Whirlpool (Refrigerator & Freezer Repair)
by tomkarl419 3 years ago
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 4 years ago
Whirlpool In Door Ice maker Problems (Dishwasher Repair)
GE Ice Maker Problems (Refrigerator & Freezer Repair)
by GM1123 10 years ago
GE Arctica Side-by-Side Ice Maker Problems (Refrigerator & Freezer Repair)
by coondog 12 years ago
by K7527 12 years ago
by ejg593 12 years ago
I bet you get tired of seeing threads titled "Ice maker problems" (Refrigerator & Freezer Repair)
by highdensity10 12 years ago
Ice maker problems (Refrigerator & Freezer Repair)
by vernjust 12 years ago
by nanette4060 13 years ago
Samsung Ice Maker problems (Refrigerator & Freezer Repair)
by bjc7 14 years ago
by emenemenem 14 years ago
Ice Maker problems again after replacing parts (Refrigerator & Freezer Repair)
by hooliek 14 years ago
by luiV 14 years ago
ice maker problems-help (Refrigerator & Freezer Repair)
by gramm 14 years ago
