those the selenoid cause for the motor not to spin? i got a problem with the ice maker in my whirlpool ed25pqxfw02 it doesnt dispense ice the auger wont spin :(
Remove the ice container and the auger motor bracket. Tape in the door light switch. Push and hold the ice cube lever on the dispenser and check for 120 VAC at the auger motor terminals and the solenoid terminals for both cubed and crushed ice options. Post the results. Here are the breakdown diagrams and Replacement parts for WHIRLPOOL ED25PQXFW02 | AppliancePartsPros.comGene.
i follow instructions i tape the door light switch test the auger motor for 120vac and the selenoid i didnt get no vac at all but the light turn on just fine
Originally Posted by: jorgey64  i follow instructions i tape the door light switch test the auger motor for 120vac and the selenoid i didnt get no vac at all but the light turn on just fine You did not say if you pushed the ice cubes release lever while doing that test. Gene.
i push the lever and switch from ice dispenser to crusher
how do i remove the overlay front cover ?
The overlay is self adhesive. You have to be very careful not to damage it because the white overlay is no longer available. Only almond one is still available. - The overlay Part number: AP3046851
