elmero57
#1 Posted : Thursday, June 4, 2009 11:59:51 AM(UTC)
elmero57
So this what is going on it is not cooling at all
I checked it out by the steps in the how to sections
put in new temp control
put in new defrost temp
put in new defrost switch
It still does no cool
Compressor is running low side 30psi High side 150psi
compressure is luke warm to the touch
Now I'm lost Help
applianceman
#2 Posted : Friday, June 5, 2009 8:34:02 AM(UTC)
applianceman
I hate to say but if it has 30 psi on the low side the compressor is bad. If it were low on gas or restricted it would be in a vacuum (below 0 psi). The pressure on the low side should be around 0 psi.
For more on do-it-yourself appliance repair visit Appliance Repair Guide For All Major Home Appliances
elmero57
#3 Posted : Friday, June 5, 2009 12:05:10 PM(UTC)
elmero57
Now I'm lost Help
OK
The compressor and fans all run
The pressure 30psi low/150psi high with fridge Off
The pressure-17psi Low/165psi high with fridge running
applianceman
#4 Posted : Friday, June 5, 2009 12:22:52 PM(UTC)
applianceman
Ok, that makes more sense its either low on gas or the capillary tube is stopped up. On some of those old models it was very common for the capillary tube to stop up and the compressor had to be replace to fix it. It is very hard to tell if its low on gas or the cap tube is stopped up. Note that if it’s low on gas you need to find and repair the leak or it will just be a temporary repair job.
The low side pressure with the compressor running should be like 0-5 psi.
elmero57
#5 Posted : Friday, June 5, 2009 12:57:22 PM(UTC)
elmero57
Ok so basiclly Ive got to get it a shot of freon to see if that helps or have system broke down replace the thing that looks like a cigar case
This has turned into a project for me now to learn a little something new
The wife fixed her refigerator problem with a new one
Kenmore 106.74203402 fridge/freezer not cooling (Refrigerator & Freezer Repair)
by ryancg 5/26/2024 7:58:26 PM(UTC)
whirlpool fridge/freezer not cooling to proper temperature (Refrigerator & Freezer Repair)
by stephenb489 9/11/2014 6:23:22 AM(UTC)
Fridge/Freezer not cooling. (Refrigerator & Freezer Repair)
by todd2371 4/29/2014 5:12:09 AM(UTC)
Frigidaire fridge/freezer not cooling and fan issues (Refrigerator & Freezer Repair)
by Eric Z 3/7/2014 1:09:54 PM(UTC)
Apartment mini-fridge/freezer not cooling (Refrigerator & Freezer Repair)
by cougartrace 4/10/2013 3:47:37 AM(UTC)
Amana fridge/freezer not cooling (Refrigerator & Freezer Repair)
by calumnicol 8/21/2012 4:04:38 AM(UTC)
Another Fridge/Freezer not cooling (Refrigerator & Freezer Repair)
by carjeff 4/30/2012 7:32:40 AM(UTC)
GE side by side fridge/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by Lou7 4/23/2012 8:36:19 PM(UTC)
Fridge/Freezer not cooling evenly (Refrigerator & Freezer Repair)
by DaneKast 10/14/2011 8:55:25 AM(UTC)
Fridge/freezer not cooling properly (Refrigerator & Freezer Repair)
by chouseal 7/23/2011 9:42:13 AM(UTC)
Kitchenaid Fridge/freezer not cooling (Refrigerator & Freezer Repair)
by robnuss 7/8/2011 11:42:24 PM(UTC)
Fridge/Freezer Not Cooling, Compressor Hot (Refrigerator & Freezer Repair)
by ryanej 4/20/2011 5:40:52 PM(UTC)
GE Fridge/Freezer Not Cooling Freezer Properly (Refrigerator & Freezer Repair)
by woody1397 2/2/2011 2:27:18 PM(UTC)
Fridge/freezer not cooling GE model # gts18jcparww (Refrigerator & Freezer Repair)
by timdogg 12/22/2010 7:02:09 PM(UTC)
by Peekin 12/6/2010 8:47:47 AM(UTC)
