Rank:: Member
freezer occasionally goes up to +50°F, but I only see that once every few days. Mostly it stays -10 to -20.
The frig stays in the +30 to +40° F and never gets warmer. Now i only have one thermometer, so i cant check them both at the same time.
GE GTS18GBSDRWW
ideas what is wrong and how to test?
tks, pa
Rank:: Member
ice is forming in the inside of walls and shelf in freezer.
Rank:: Member
fan in freezer blows cold air and is on most of the time. I took the fan housing off and nothing else there. BTW I unplugged the fridge and 4 hours later opened the freezer and all the ice was still cold and dry. I then left the door open and within 3 minutes the ice was melting and dripping.
Rank:: Member
removed back plate freezer. watched as it went into defrost. 20 minutes later the heater was still red and it was 55°F in there. Sometime later heater turned off, fan went on and it started cooling again.
Rank:: Member
cut thermostat def WR50X10073 out of circuit and heater turns off. Thermostat def WR50X10073 reads 1.8meg ohms at room temperature.
Rank:: Member
it says 39vte31 40026 L64-41F s17409e 238c2672p004
Rank:: Member
replaced defrost thermostat. Less then 12 hours after plugging fridge back in, ice is forming in the freezer compartment on shelves, ceiling, and back wall. now what?
Rank:: Member
this fridge has been working fine for several years, then all of a sudden, it's malfunctioning. The thermostat tested bad, but replacing it, did not help. Ice on back wall, shelves, top, and now side walls is getting worse.
