paulmars
#1 Posted : Saturday, March 31, 2018 10:25:06 AM(UTC)
paulmars
freezer occasionally goes up to +50°F, but I only see that once every few days. Mostly it stays -10 to -20.
The frig stays in the +30 to +40° F and never gets warmer. Now i only have one thermometer, so i cant check them both at the same time.
GE GTS18GBSDRWW
ideas what is wrong and how to test?
tks,
pa
paulmars
#2 Posted : Sunday, April 1, 2018 5:31:15 AM(UTC)
paulmars
ice is forming in the inside of walls and shelf in freezer.
paulmars
#3 Posted : Friday, April 20, 2018 3:36:43 PM(UTC)
paulmars
fan in freezer blows cold air and is on most of the time. I took the fan housing off and nothing else there. BTW I unplugged the fridge and 4 hours later opened the freezer and all the ice was still cold and dry. I then left the door open and within 3 minutes the ice was melting and dripping.
paulmars
#4 Posted : Monday, April 23, 2018 1:59:48 PM(UTC)
paulmars
removed back plate freezer. watched as it went into defrost. 20 minutes later the heater was still red and it was 55°F in there. Sometime later heater turned off, fan went on and it started cooling again.
paulmars
#5 Posted : Tuesday, April 24, 2018 4:10:32 AM(UTC)
paulmars
cut thermostat def WR50X10073 out of circuit and heater turns off. Thermostat def WR50X10073 reads 1.8meg ohms at room temperature.
paulmars
#6 Posted : Tuesday, April 24, 2018 1:57:43 PM(UTC)
paulmars
it says 39vte31 40026
L64-41F s17409e
238c2672p004
paulmars
#7 Posted : Sunday, May 6, 2018 7:04:30 PM(UTC)
paulmars
replaced defrost thermostat. Less then 12 hours after plugging fridge back in, ice is forming in the freezer compartment on shelves, ceiling, and back wall. now what?
paulmars
#8 Posted : Monday, May 7, 2018 1:06:47 PM(UTC)
paulmars
this fridge has been working fine for several years, then all of a sudden, it's malfunctioning. The thermostat tested bad, but replacing it, did not help. Ice on back wall, shelves, top, and now side walls is getting worse.
Guest (6)
GE DFE29JMDEES warm freezer (Refrigerator & Freezer Repair)
by wallyh3128 5/24/2023 4:52:35 AM(UTC)
Frigidaire side by side - warm freezer cold fridge - help please (Refrigerator & Freezer Repair)
by Doug427 1/23/2023 4:36:18 PM(UTC)
Whirlpool Gold Conquest: compressor constantly running & warm freezer (Refrigerator & Freezer Repair)
by dawydiuk 12/4/2016 6:11:31 AM(UTC)
Kenmore Side By Side Fridge Warm Freezer Good (Refrigerator & Freezer Repair)
by craig72 7/15/2015 9:23:52 AM(UTC)
Amana warm freezer and refer could jazz board be the issue if all tests good (Refrigerator & Freezer Repair)
by jimholstrom@yahoo.com 10/22/2014 12:58:03 PM(UTC)
warm Freezer, frozen yogurt in main section (Refrigerator & Freezer Repair)
by ABQGE 12/17/2013 7:52:41 PM(UTC)
Fridge warm freezer cold - First repair done (Refrigerator & Freezer Repair)
by phatdawg 12/5/2013 7:54:14 AM(UTC)
Refrigerator warm Freezer ok (Refrigerator & Freezer Repair)
by larbear 8/24/2013 7:24:21 PM(UTC)
Warm Freezer (Refrigerator & Freezer Repair)
by rska 6/27/2013 2:42:26 PM(UTC)
Built in Kitchenaid warm freezer occasionally (Refrigerator & Freezer Repair)
by jphemi 3/20/2013 6:46:18 PM(UTC)
Fridge is warm freezer cold (Refrigerator & Freezer Repair)
by Suzanne brugger 8/28/2012 2:39:42 PM(UTC)
regfrigerator to warm freezer ok (Refrigerator & Freezer Repair)
by hfox1 8/15/2012 9:08:52 AM(UTC)
refrigerator warm freezer ok (Refrigerator & Freezer Repair)
by Am obil 11/22/2011 7:40:42 PM(UTC)
Compressor short runs, warm freezer fridge (Refrigerator & Freezer Repair)
by Drgnflys 10/2/2011 6:42:39 PM(UTC)
Refrigerator too warm Freezer fine (Refrigerator & Freezer Repair)
by kinijean 7/13/2011 1:17:18 PM(UTC)
