Quietpower10
#1 Posted : Monday, July 2, 2012 7:52:39 PM(UTC)
Quietpower10
One day my refrigerator was doing well, and then all of a sudden I see a huge puddle leaking out of it. When I opened the freezer, almost everything inside was melted. Also, the refrigerator side was warmer than usual too.
I did the basic check of unplugging the refrigerator and replug it after 2-3 hours. Sadly that didn't work.
However, when I replug the refrigerator, I noticed that the motorish sound from behind it was making a softer sound than it originally was. Currently, my hypothesis is that the compressor must be broken or the fan is probably broken.
I would appreciate some help.
richappy2
#2 Posted : Monday, July 2, 2012 10:06:56 PM(UTC)
richappy2
take back panel off in back of fridge and listen for condenser fan and compressor if both are working, than expose evaporator and see if anything is happening. Im guessing it could be a bad defrost timer or thermostat.
richappy2
#3 Posted : Monday, July 2, 2012 10:08:49 PM(UTC)
richappy2
If its stuck in defrost mode it wont freeze so check that defrost timer and that will also kill your fans and compressor.
Quietpower10
#4 Posted : Tuesday, July 3, 2012 8:01:39 AM(UTC)
Quietpower10
I have looked behind the refrigerator too and I've noticed the condensor and compressor fan aren't working. Also, I did do some research regarding this situation and I've found a list of problems regarding my refrigerator:
- The compressor
- The overload, relay, or capacitor
- The defrost timer
- The condenser fan motor
If there were anything else I might've forgotten, please provide them to me.
richappy2
#5 Posted : Tuesday, July 3, 2012 12:05:04 PM(UTC)
richappy2
sounds about right, find that defrost timer and stick a screw driver in between its tabs and turn it until you here a click and see if those fans and the compressor start up before you start replacing anything.
jalilsystem
#6 Posted : Friday, March 3, 2017 2:37:25 AM(UTC)
jalilsystem
Refrigerator/Freezer Not Cooling (Refrigerator & Freezer Repair)
by sytipton 7/18/2017 12:39:26 PM(UTC)
Whirlpool Refrigerator/Freezer not cooling Intermittenly (Refrigerator & Freezer Repair)
by mshilko 9/14/2016 9:33:30 AM(UTC)
Whirlpool Refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by tomk000 8/8/2015 2:11:22 PM(UTC)
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 5/27/2015 10:24:46 AM(UTC)
Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by dansally 7/14/2014 4:07:03 PM(UTC)
GE refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by dave27 4/1/2013 3:54:30 PM(UTC)
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 11/17/2012 11:44:40 AM(UTC)
GE Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by Steph Paine 10/28/2012 12:36:56 PM(UTC)
Refrigerator/Freezer not cooling properly (Refrigerator & Freezer Repair)
by dollar13 7/12/2012 11:02:06 AM(UTC)
by t38263 5/29/2012 7:29:13 PM(UTC)
by jerosier 5/7/2012 12:09:11 PM(UTC)
by GPete76 2/28/2012 2:06:14 PM(UTC)
Samsung refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by Deldolfan 12/24/2011 6:35:05 AM(UTC)
Refrigerator/Freezer Not cooling (Refrigerator & Freezer Repair)
by pendries 8/22/2011 1:54:22 PM(UTC)
admiral refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by sammay55 7/11/2011 7:18:51 PM(UTC)
