Quietpower10
#1 Posted : 13 years ago
Quietpower10
One day my refrigerator was doing well, and then all of a sudden I see a huge puddle leaking out of it. When I opened the freezer, almost everything inside was melted. Also, the refrigerator side was warmer than usual too.
I did the basic check of unplugging the refrigerator and replug it after 2-3 hours. Sadly that didn't work.
However, when I replug the refrigerator, I noticed that the motorish sound from behind it was making a softer sound than it originally was. Currently, my hypothesis is that the compressor must be broken or the fan is probably broken.
I would appreciate some help.
richappy2
#2 Posted : 13 years ago
richappy2
take back panel off in back of fridge and listen for condenser fan and compressor if both are working, than expose evaporator and see if anything is happening. Im guessing it could be a bad defrost timer or thermostat.
richappy2
#3 Posted : 13 years ago
richappy2
If its stuck in defrost mode it wont freeze so check that defrost timer and that will also kill your fans and compressor.
Quietpower10
#4 Posted : 13 years ago
Quietpower10
I have looked behind the refrigerator too and I've noticed the condensor and compressor fan aren't working. Also, I did do some research regarding this situation and I've found a list of problems regarding my refrigerator:
- The compressor
- The overload, relay, or capacitor
- The defrost timer
- The condenser fan motor
If there were anything else I might've forgotten, please provide them to me.
richappy2
#5 Posted : 13 years ago
richappy2
sounds about right, find that defrost timer and stick a screw driver in between its tabs and turn it until you here a click and see if those fans and the compressor start up before you start replacing anything.
jalilsystem
#6 Posted : 8 years ago
jalilsystem
Refrigerator/Freezer Not Cooling (Refrigerator & Freezer Repair)
by sytipton 8 years ago
Whirlpool Refrigerator/Freezer not cooling Intermittenly (Refrigerator & Freezer Repair)
by mshilko 9 years ago
Whirlpool Refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by tomk000 10 years ago
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 10 years ago
Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by dansally 11 years ago
GE refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by dave27 12 years ago
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 12 years ago
GE Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by Steph Paine 12 years ago
Refrigerator/Freezer not cooling properly (Refrigerator & Freezer Repair)
by dollar13 13 years ago
by t38263 13 years ago
by jerosier 13 years ago
by GPete76 13 years ago
Samsung refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by Deldolfan 13 years ago
Refrigerator/Freezer Not cooling (Refrigerator & Freezer Repair)
by pendries 14 years ago
admiral refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by sammay55 14 years ago
