t38263
#1 Posted : 13 years ago
t38263
my 9 yr old refrigerator/freezer suddenly stopped cooling. the fan works and the controls are lit. the compressor will not start and does not make any noise. the coils were dusty so i cleaned the coils. i checked the run cap and its ok. i checked the overload switch and it has continuity. i just replaced the ptcr relay and it did not solve the problem. what do you think i should do next? change the ckt board, temp sensors or something else? i really dont want to attempt to change the compressor... i dont know how to solder the copper tubes and the cost seems too high. i read something about checking the compressor resistance readings and verifying power to the compressor. also, i read that a lot of people have difficulty modifying the replacement ckt board for their particular unit. please advise.
#2 Posted : 13 years ago
I would suspect bad solder connections on the back of the motherboard
(AP4436216)
GE refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by dave27 12 years ago
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 12 years ago
GE Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by Steph Paine 12 years ago
GE Refrigerator/Freezer Not Cooling Enough (Refrigerator & Freezer Repair)
by eguerns 15 years ago
