pendries
#1 Posted : Monday, August 22, 2011 1:54:22 PM(UTC)
pendries
A couple weeks ago my refrigerator/freezer stopped working. It was not running at all. After cleaning the coils and verifying that the coils in the back of the freezer were not frosted up I assumed the worst, compressor failure. After some poking around I figured out that if I slid the thermostat to a colder setting, the compressor would kick in and cool the unit. Later , the unit would fail to kick in again unless I rapped on the thermostat area, Than it would run again. So I figured I had found my problem and ordered and installed the temp. control assembly. The unit kicked in as it should, A day or two later the unit would not kick in again unless I rapped on the thermostat again, The wire connections all seem OK, How likely is it that I received a faulty thermostat? Is there something else wrong causing the thermostat to fail. What else can I check? I hear alot of talk about the defrost control board on this model, Could that be the culprit, Can I test or bypass this to verify. Any help would be appreciated.:confused:
#2 Posted : Tuesday, August 23, 2011 1:28:11 AM(UTC)
I would remove the control panel cover and pull out the adaptive defrost board and tap on it to confirm that is the problem.Order it here, AP4070403
Refrigerator/Freezer Not Cooling (Refrigerator & Freezer Repair)
by sytipton 7/18/2017 12:39:26 PM(UTC)
Whirlpool Refrigerator/Freezer not cooling Intermittenly (Refrigerator & Freezer Repair)
by mshilko 9/14/2016 9:33:30 AM(UTC)
Whirlpool Refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by tomk000 8/8/2015 2:11:22 PM(UTC)
Amana Refrigerator/Freezer Not Cooling or Freezing (Refrigerator & Freezer Repair)
by willie1280 5/27/2015 10:24:46 AM(UTC)
Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by dansally 7/14/2014 4:07:03 PM(UTC)
GE refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by dave27 4/1/2013 3:54:30 PM(UTC)
GE Refrigerator/freezer not cooling or freezing (Refrigerator & Freezer Repair)
by n4moe 11/17/2012 11:44:40 AM(UTC)
GE Refrigerator/Freezer not cooling (Refrigerator & Freezer Repair)
by Steph Paine 10/28/2012 12:36:56 PM(UTC)
Refrigerator/Freezer not cooling properly (Refrigerator & Freezer Repair)
by dollar13 7/12/2012 11:02:06 AM(UTC)
by Quietpower10 7/2/2012 7:52:39 PM(UTC)
by t38263 5/29/2012 7:29:13 PM(UTC)
by jerosier 5/7/2012 12:09:11 PM(UTC)
by GPete76 2/28/2012 2:06:14 PM(UTC)
Samsung refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by Deldolfan 12/24/2011 6:35:05 AM(UTC)
admiral refrigerator/freezer not cooling (Refrigerator & Freezer Repair)
by sammay55 7/11/2011 7:18:51 PM(UTC)
