JT
JT REPAIRE
#1 Posted : Monday, April 18, 2016 10:56:55 AM(UTC)
JT REPAIRE
My side by side fridge /freezer stopped cooling and i did the tap test on the thermostat and it came on and the freezer got down to about -8 but the fridge was about +50. When it turned off it wouldn't start without tapping on the thermostat so i purchased a new one from you. Now it starts and the freezer still gets real cold but the fridge is still warm, going thru your threads i started checking more and found the air baffle door closed. I ran the test you have posted and when the door is closed it has continuity on the 2-3 terminals and not on 1+2 or 3+6. with the thermostats in the normal settings.
I turned the new refrigerator thermostat off and the baffle door opens and the1+2 terminals show 14 volts the 2+3 show no continuity and the 3+6 has
continuity.
GE JT5000SF6SS display failed - 2 years old (Oven Repair (including Ranges and Cooktops))
by bkorb 3/6/2023 11:15:53 AM(UTC)
Whirlpool Washer LSQ8543JT1 Transmission Gear (Washer Repair)
by wvdiesel 2/20/2021 9:55:50 AM(UTC)
GE double oven JT5500SF6SS (Oven Repair (including Ranges and Cooktops))
by cjoneill 12/6/2020 2:00:27 PM(UTC)
GE Double Wall Oven jt5500sf5ss doors locked with no power after self clean (Oven Repair (including Ranges and Cooktops))
by mtvu11 9/28/2019 9:19:27 AM(UTC)
LG EBR75234703 PCB, LG TCA38091801 Compressor and LG CJT30000002 (Refrigerator & Freezer Repair)
by anotherbrokenKenmoreffs 8/15/2019 9:24:08 AM(UTC)
whirlpool GEX9868jt2. Was getting E1 error. replaced thermistor. Still getti (Dryer Repair)
by Garyatmaui 11/16/2017 12:19:47 PM(UTC)
GE Monogram Oven ZET3038 (same as JT930) no display or oven light (Oven Repair (including Ranges and Cooktops))
by pacasey 6/19/2015 8:57:25 PM(UTC)
GE JTP20 Oven F9 error (Oven Repair (including Ranges and Cooktops))
by btl512 2/9/2012 12:37:40 PM(UTC)
How do I gain access to the heating element of a whirlpool gold dryer: GEQ8858JT1 (Dryer Repair)
by lonchaney 11/19/2010 5:04:37 PM(UTC)
GE Profile Microwave Oven combo JT965SSOK2SS (Microwave Repair)
by herman_the_german 10/16/2010 11:48:40 AM(UTC)
Ge Oven JTP15 F2 F3 F5 error codes (Oven Repair (including Ranges and Cooktops))
by rountad 8/31/2010 11:06:07 AM(UTC)
GE Model JTP85 Turntable and Light not working (Microwave Repair)
by Lancair 4/15/2010 5:39:56 PM(UTC)
GE JT915 Single Oven Temperature Problem (Oven Repair (including Ranges and Cooktops))
by jimh4938 3/14/2010 4:30:53 AM(UTC)
GE Buil-in Microwave and Oven combo, JTP86B0F2BB (Oven Repair (including Ranges and Cooktops))
by CyberCrawler 11/13/2009 8:35:03 AM(UTC)
JTP56CODICC - GE Profile Double Oven (Oven Repair (including Ranges and Cooktops))
by G.B. 6/24/2008 6:13:58 AM(UTC)
