Garyatmaui
#1 Posted : Thursday, November 16, 2017 12:19:47 PM(UTC)
Garyatmaui
Was getting E1 error. replaced thermistor. Still getting the same error. Dryer heats well, doesnt seem to dry everything initial cycle though.
ThatGuy
#2 Posted : Thursday, November 16, 2017 4:23:19 PM(UTC)
ThatGuy
Groups: Expert
Drying is a combination of heat and airflow.
Check your vent and make sure its clean and unrestricted all the way to the outside. Check inside the lint filter area too.
I also found this on another page.
Core issue: Why does my Whirlpool Gold dryer shut off and give an E1 code, model number GGX9868JQ0?
Resolution: The machine control has detected a open thermal sensor.
In some cases the control can be non-functioning and not accept any activation from the customer interface (keypad), to clear and restart the control follow the below listed steps:
Unplug or turn the circuit breaker off for a 30 second period.
Reconnect the unit to the power source, breaker back on or plug into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Garyatmaui
#3 Posted : Thursday, November 16, 2017 5:08:37 PM(UTC)
Garyatmaui
Thanks, I cleaned dust and lint out of dryer today when I changed the thermistor. I will check vent through the basement tomorrow. I will also check the thermal sensor
gary
