AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
whirlpool GEX9868jt2. Was getting E1 error. replaced thermistor. Still getti
Was getting E1 error. replaced thermistor. Still getting the same error. Dryer heats well, doesnt seem to dry everything initial cycle though.
Groups: Expert
Drying is a combination of heat and airflow.
Check your vent and make sure its clean and unrestricted all the way to the outside. Check inside the lint filter area too.
I also found this on another page.
Core issue: Why does my Whirlpool Gold dryer shut off and give an E1 code, model number GGX9868JQ0?
Resolution: The machine control has detected a open thermal sensor.
In some cases the control can be non-functioning and not accept any activation from the customer interface (keypad), to clear and restart the control follow the below listed steps:
Unplug or turn the circuit breaker off for a 30 second period.
Reconnect the unit to the power source, breaker back on or plug into the wall outlet.
Press the Pause/Cancel/Stop button twice to clear the PF in the display.
Try to start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
Thanks, I cleaned dust and lint out of dryer today when I changed the thermistor. I will check vent through the basement tomorrow. I will also check the thermal sensor gary Originally Posted by: ThatGuy  Drying is a combination of heat and airflow.
Dryer Repair
