2 Pages12>
chash
#1 Posted : Thursday, August 6, 2015 9:12:57 AM(UTC)
chash
replaced heat element and thermal fuse and still no heat. what else could be wrong?
#2 Posted : Thursday, August 6, 2015 11:01:20 AM(UTC)
Your model number does not come up.
I tried here, Sears and the Whirlpool site.
Find your model number - AppliancePartsPros.com
On most units the thermal fuse on the blower kills power to the motor when blown not the heating element.
Have you checked the power?
The heating element on an electric dryer requires the full 240 volts.
Try flipping the breaker off/on slowly a couple times. Sometimes you can loose half the line without actually tripping the breaker.
Check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
On most dryers the heater circuit includes the heater, a thermal cut-off, a hi-limit thermostat, a centrifugal switch on the motor and one set of contacts in the timer. This is for dryers that use a mechanical timer and does not apply to units with an electronic control board.
chash
#3 Posted : Thursday, August 6, 2015 11:55:11 AM(UTC)
chash
try this number W10150610A. tested current as stated in your reply and everything checked out ok. thanks.
#4 Posted : Thursday, August 6, 2015 12:31:04 PM(UTC)
Sorry no joy with that number either.
If this is not a USA unit I may not be able to find info on it.
chash
#5 Posted : Thursday, August 6, 2015 2:00:54 PM(UTC)
chash
last number WED 5560SQ0
#6 Posted : Friday, August 7, 2015 1:01:49 AM(UTC)
BINGO!!!
Parts for Whirlpool WED5560SQ0 Dryer - AppliancePartsPros.com
See the attachment for your wiring diagram.
I am assuming that you have a meter.
Set the meter to it's most sensitive resistance scale usually 200 ohms.
Set the timer to the position where you do not have heat.
Unplug the unit.
Attach one meter lead (clip or tape it) to the L1 prong on the line cord and leave it there.
Now work your way back through the heater circuit.
BK on the timer should be 0 ohms.
R on the timer should be 0 ohms.
Both sides of the thermal cutoff, the operating thermostat and the hi-limit thermostat, all should be 0 ohms.
Thermostat side of the heater should be 0 ohms.
Other side of the heater should be around 8 to 12 ohms.
M on the motors centrifugal switch should be 8 to 12 ohms.
With luck you will find what part/connection that is open.
If all is OK then odds are that the problem is with the centrifugal switch.
Often this is a bad connection re: a wire has come off.
But sometimes it is a bad switch.
chash
#7 Posted : Saturday, August 8, 2015 3:17:39 AM(UTC)
chash
seems like only 120 volts at heater element. at terminal block, red to white is 120 and red to black is 240 while dryer is on.
#8 Posted : Saturday, August 8, 2015 6:20:32 AM(UTC)
When you measure the 120 at the heater element are you measuring across the element or using Neutral/ground as the reference re: one meter lead to Neutral or ground.
chash
#9 Posted : Saturday, August 8, 2015 9:55:08 AM(UTC)
chash
one lead to ground.
chash
#10 Posted : Saturday, August 8, 2015 10:15:06 AM(UTC)
chash
either side of element to ground reads 120. across element there is no reading.
Guest (4)
New Kenmore Elite 796 Gas Dryer Won't Heat (Dryer Repair)
by Guest 12/26/2022 1:54:20 PM(UTC)
Whirlpool Duet Dryer won't heat anymore (Dryer Repair)
by Guest 3/31/2021 5:35:15 AM(UTC)
Dryer won't heat consistently – Is an RCA model dryer actually GE? (Dryer Repair)
by OpsTao 12/11/2020 7:20:38 AM(UTC)
Samsung Dryer Won't heat no matter what I do (Dryer Repair)
by coachroy 10/16/2020 10:58:40 AM(UTC)
Whirlpool LGT7848AQ1 dryer won't heat (Dryer Repair)
by spiggman 9/19/2020 4:47:12 PM(UTC)
Kenmore Electric Dryer Won't Heat (Dryer Repair)
by ginakra 9/21/2017 11:03:29 AM(UTC)
Dryer won't heat (Dryer Repair)
by ncoles6 12/23/2016 6:32:33 PM(UTC)
Whirlpool Dryer won't heat (Dryer Repair)
by spelding 9/16/2016 5:48:12 AM(UTC)
by Kate123 3/5/2016 7:28:08 AM(UTC)
Stumped - Samsung Dryer Won't Heat (Dryer Repair)
by TankusKC 1/6/2016 8:18:18 AM(UTC)
by haymon 1/5/2016 5:47:24 PM(UTC)
by wgomezp1 10/12/2015 4:49:48 PM(UTC)
Gas dryer won't heat (Dryer Repair)
by pino2424 4/21/2015 5:45:55 PM(UTC)
A different my dryer won't heat problem (Dryer Repair)
by mikeysotp 11/20/2014 5:05:34 AM(UTC)
Admiral Dryer won't heat (Dryer Repair)
by MarkMLP 11/12/2014 6:25:55 AM(UTC)
2 Pages12>
