2 Pages12>
massimo33162
#1 Posted : Friday, November 22, 2013 6:59:58 AM(UTC)
massimo33162
just bought new igniter and it still does not work -no clicking sound- strangely when you put the igniter on for the next burner -this igniter starts clicking -so in order to light this burner yu have to light the burner next to it -so i would say the igniter does work but indirectly ...in other words if you want to light this broken burner - (since the gas comes out but no clicking sound ) yu need to light another burner first -i know its not the end of the world but i did buy a new igniter it would be nice if this worked on its own like it was supposed to
Appliance Ninja
#2 Posted : Friday, November 22, 2013 7:12:04 AM(UTC)
Appliance Ninja
The issue is likely with the switch on the valve shaft, not the igniter. Each valve has a small switch that, when the valve is turned on, energizes the spark module so the igniters will spark. I suspect that switch is faulty. May I please have your model number so I am able to provide you with accurate, model specific information?
massimo33162
#3 Posted : Friday, November 22, 2013 7:19:18 AM(UTC)
massimo33162
frigidaire(electrolux)- PLCS389ACC --THANK YU -I BET THE IGNITER DID NOT EVEN HAVE TO BE REPLACED
Appliance Ninja
#4 Posted : Friday, November 22, 2013 7:26:51 AM(UTC)
Appliance Ninja
Thank you! Number 3 in the picture below is the igniter switch. I have posted a link to that part below. I agree that the original igniter was probably okay.
Frigidaire 316032002 Switch, Ign - AppliancePartsPros.com
Appliance Ninja attached the following image(s):
massimo33162
#5 Posted : Friday, November 22, 2013 7:28:23 AM(UTC)
massimo33162
massimo33162
#6 Posted : Friday, November 22, 2013 7:41:04 AM(UTC)
massimo33162
Could Yu Send Me Any Directions Putting It In -is It Hard To Put In? Assuming I Have To Take The Whole Range Top Off As Well ..thank Yu Again
Appliance Ninja
#7 Posted : Friday, November 22, 2013 7:41:11 AM(UTC)
Appliance Ninja
Your information is above....
massimo33162
#8 Posted : Friday, November 22, 2013 7:45:50 AM(UTC)
massimo33162
Ok Thank Yu
Appliance Ninja
#9 Posted : Friday, November 22, 2013 7:47:27 AM(UTC)
Appliance Ninja
You are very welcome, have a great weekend!
massimo33162
#10 Posted : Friday, November 22, 2013 9:14:12 AM(UTC)
massimo33162
one more thing the warmer draw on this unit does not close properly- just bought a new rail from you and that was not the problem -it might be (has to be) the female rails -cant for the life of me understand why the draw does not closse all the way -mid way the draw jams -are those bering glides supposed to move or be stationary ? hard to see because you cant see what is jamming the slide warmer door
Guest (10)
Oven Buttons not working and igniter problem (Oven Repair (including Ranges and Cooktops))
by Paul Briant 4/14/2013 11:31:39 AM(UTC)
Do I have an igniter problem? (Oven Repair (including Ranges and Cooktops))
by ginbeach 9/5/2012 1:45:46 PM(UTC)
Dryer Igniter Problem? (Dryer Repair)
by Danielwolfmountain 1/23/2012 1:52:16 PM(UTC)
Thermador PGR304ZS igniter problem (Oven Repair (including Ranges and Cooktops))
by mtangney 11/24/2010 10:10:59 AM(UTC)
GE Range igniter problem (Oven Repair (including Ranges and Cooktops))
by chuckcarlino 9/15/2010 9:58:25 AM(UTC)
GE Stove/Range, range Igniter problem (Refrigerator & Freezer Repair)
by chuckcarlino 9/15/2010 3:34:22 AM(UTC)
Magic Chef top igniter problem (Oven Repair (including Ranges and Cooktops))
by techsan47 9/13/2010 11:04:58 AM(UTC)
igniter problem? (Heating, Ventilation, and Air Conditioning (HVAC))
by ski1of5 3/19/2010 10:42:39 AM(UTC)
Igniter Problems (Oven Repair (including Ranges and Cooktops))
by dp1313 12/23/2009 2:02:01 PM(UTC)
More igniter problems (Oven Repair (including Ranges and Cooktops))
by dp1313 12/5/2009 2:24:23 PM(UTC)
Bosch Cooktop Igniter Problem (Oven Repair (including Ranges and Cooktops))
by ddoughty56 7/26/2009 10:50:24 AM(UTC)
GE JGP933 Faulty Igniter Problem (Oven Repair (including Ranges and Cooktops))
by Scott Lawson 1/5/2009 4:29:14 PM(UTC)
GE Cooktop Igniter problems (Oven Repair (including Ranges and Cooktops))
by KatyTx 12/27/2008 7:27:46 PM(UTC)
GE Profile Igniter Problem (Oven Repair (including Ranges and Cooktops))
by tim a 8/29/2008 10:53:41 PM(UTC)
2 Pages12>
