2 Pages12>
mmcgarcia
#1 Posted : 12 years ago
mmcgarcia
Hello, I checked the ohms on the motor connector: orange to blue, orange to white, black to red, black to violet and yellow to orange then I checked the harness connector yellow to white and only read 1 ohm, I believe the coil is reading open any other advice or checks I can perform. The lid switch is good, the belt is good, checked the transmission and its good installed a new timer switch, your help is greatly appreciated, Wife is losing faith in my mechanical skills trying to show I still got it, ha ha
scott5495
#2 Posted : 12 years ago
scott5495
i'm not trying to be funny, but have you checked your wall receptacle for power?
fairbank56
#3 Posted : 12 years ago
fairbank56
Groups: Expert
I assume the washer filled since you say it won't agitate and it must be full to go into agitate. If you do have power to the washer, does the motor make any sound (humming)? If not, sure sounds like lid switch if motor windings check out. You should not read anything from motor harness connector yellow to white (motor unplugged). Are you sure your reading 1 ohm or is it reading infinity (open)? When you place it in spin mode, does the timer advance on it's own? I don't have your exact wiring diagram, can you provide a clear hi-res photo of it? Should be behind the control panel.
Eric
mmcgarcia
#4 Posted : 12 years ago
mmcgarcia
I'm not trying to be funny back but yes I have power, I can hear a humming sound I advance the timer to spin or agitate and it won't , now not to sound like a dummy but I working out of my garage does there need to be water in the tub because there is not. The machine is not connected to any water supply:o
fairbank56
#5 Posted : 12 years ago
fairbank56
Groups: Expert
Can't help you if you don't respond to the questions. No water required for testing in spin mode.
Eric
mmcgarcia
#6 Posted : 12 years ago
mmcgarcia
Eric, the motor does not make any noise, I'm reading 1 ohm in the open( infinity), the timer does advance. Having trouble uploading a photo, how do check continuity on the lid switch?;)
fairbank56
#7 Posted : 12 years ago
fairbank56
Groups: Expert
To check the lid switch, unplug the washer, check continuity between the power plug neutral (wide blade) and the orange wire at the motor connector. Should read zero ohms (short) with lid closed.
Eric
mmcgarcia
#8 Posted : 12 years ago
mmcgarcia
Checked continuity on the lid switch cannot get 0 ohms.:D
mmcgarcia
#9 Posted : 12 years ago
mmcgarcia
I checked the continuity on the lid switch and cannot get 0 ohms
fairbank56
#10 Posted : 12 years ago
fairbank56
Groups: Expert
Sounds like you have a faulty lid switch however it looks like you have a double pole type? Need to see your wiring diagram to help any further.
Eric
Whirlpool WTW4815EW1 Washer Won't Spin or Agitate (Washer Repair)
by dann1551 4 years ago
Washer won't spin or agitate (Washer Repair)
by dhughes 8 years ago
GE washer won't spin or agitate. (Washer Repair)
by Eric9999 9 years ago
GE Washer won't spin or agitate (Washer Repair)
by whovian2015 10 years ago
Washer Won't Spin or Agitate, but Drains Properly (Washer Repair)
by Levistahl 11 years ago
washer won't spin or agitate (Washer Repair)
by tibbs1212 11 years ago
GE Hydrowave washer won't spin or agitate (Washer Repair)
by lilajfischer 11 years ago
Hotpoint washer won't spin or agitate (Washer Repair)
by cmccms 11 years ago
Kenmore washer won't spin or agitate (Washer Repair)
by jwes 11 years ago
Whirlpool Washer won't Spin or Agitate (Washer Repair)
by Jimmimech 11 years ago
GE washer won't spin or agitate (Washer Repair)
by unclejohnforever 12 years ago
washer won't spin or agitate.. and grinding noise (Washer Repair)
by mjk 12 years ago
GE Hydrowave Washer won't spin or agitate (Washer Repair)
by budmanluvtofish 12 years ago
Washer won't spin or agitate, fills and drains ok (Washer Repair)
by cbinaz 13 years ago
Ge washer won't spin or agitate (Washer Repair)
by Pwat300 13 years ago
2 Pages12>
