Eric9999
#1 Posted : 9 years ago
Eric9999
GE Washer WBSR3140G2WW symptom: fills with water, drains, no agitate, no spin, drain motor continues to run. Motor replaced, lid switch bypassed, timer replaced, fuse was not blown (but I replace the fuse with the wire provided with the replacement motor). Belt ok, motor basket spin freely by hand. Motor LED flashed "Normal Standby" (one second on, 1 second off).
[URL="http://www.justanswer.com/appliance/49qpb-washer-will-empty-pump-keeps-running-till-shuts.html#ixzz3uyxoVbuC"][/URL]
sidfink43
#2 Posted : 9 years ago
sidfink43
Check the wiring between the control unit and the motor but I think your mode shifter is bad, just because that's about the only thing left to be bad. You should have gotten an error code though. I assume you did the reset but even so, try it again.
Eric9999
#3 Posted : 9 years ago
Eric9999
Thanks the original motor flashed normal, the "new" motor which was shipped in a box which had been opened/re-taped shut several times flashes 6. Thinking I got a "new" defective motor. Having another shipped, will update this thread after I get the new motor. I really don't think the mode shifter is the issue but I agree it's the only thing left lol
Eric9999
#4 Posted : 9 years ago
Eric9999
Hi, just wanted to follow-up. I ordered another motor through ******** and the washer now works perfectly. Net: The prior "new motor" I installed was defective.
sidfink43
#5 Posted : 9 years ago
sidfink43
Great, that happens occasionally so glad you were able to get a good replacement and thanks for updating us.
GE washer won't spin or agitate. Motor? Mode shifter? (Washer Repair)
by kzinti83 14 years ago
