anthony calise
#1 Posted : 16 years ago
anthony calise
Can you please tell me where the water valve AP2039339 is located and what I have to do to replace it?
#2 Posted : 16 years ago
Here is a parts breakdown
Model Search
It is behind the kick plate, left hand side.
Turn the water off and simply replace it.
Have a pan there to catch the water that will spill out.
Why do you want to replace it, if it is just because you have no water there are a number of other things that can cause this.
1. Valve not getting power
2. Overfill switch not working either, the switch or the float.
3. Inlet filter screen in the valve is plugged
Bosch Refrigerator Water Valve Stuttering (Refrigerator & Freezer Repair)
by Mattman928 5 years ago
Water valve chatter/low output (Refrigerator & Freezer Repair)
by mmisko 5 years ago
Use other water valves (Washer Repair)
by zuki1100 6 years ago
Water leak after replacing water valve (Refrigerator & Freezer Repair)
by gmanly 6 years ago
Voltages/Signal going to water valve (Refrigerator & Freezer Repair)
by PT2000 8 years ago
Would you change water valves? (Washer Repair)
by NSXBill 8 years ago
Leaking Water Valve W10340983 (Refrigerator & Freezer Repair)
by doubldc 8 years ago
Hot Water valve in home (Washer Repair)
by Amana_watt? 9 years ago
New GE dishwasher - leaking at water valve (Dishwasher Repair)
by cbrandel 10 years ago
How to access the water valve (Dishwasher Repair)
by bradawk 10 years ago
Water valve question (Dishwasher Repair)
by rich22 10 years ago
ice maker water valve (Refrigerator & Freezer Repair)
by doug1512 10 years ago
Jenn-Air/Whirlpool Free Standing Ice Maker Water Valve (Refrigerator & Freezer Repair)
by mjbosha 10 years ago
Do I need to relpace Inlet Water Valve? How? (Washer Repair)
by rodrigt 11 years ago
Dual water valve (Refrigerator & Freezer Repair)
by mikegayron 11 years ago
