nanette4060
#1 Posted : Tuesday, May 22, 2012 5:43:52 PM(UTC)
nanette4060
Ice maker overflowing water when it's in the process of filling for next ice batch. Water overflows then seizes. it does it every time it makes the ice. it fills up to make the ice then it overflows, then it stops, makes the ice, then it fills up to make the ice for the next batch and then the cycle starts all over. Can I repair this myself? What parts do I need, and is there instructions for this.
#2 Posted : Wednesday, May 23, 2012 5:33:10 PM(UTC)
If it's overflowing then the problem is a bad water inlet valve.
If the ice maker itself is leaking water, then the ice maker has to be replaced.
- The water inlet valve Part number: 241803701
- The ice maker Part number: 5303918277
timmer23
#3 Posted : Sunday, June 3, 2012 5:03:04 PM(UTC)
timmer23
I just replaced the ice maker.works great. ice will dispense crushed on both cube and crushed settings.
#4 Posted : Monday, June 4, 2012 12:33:35 PM(UTC)
Remove the ice container and the motor cover (#20 at the diagram). Check the solenoid (#45) for continuity.
Tape in the light switch. Remove the wires from the solenoid and connect the voltmeter probes to them. Check for 120 VAC between these wires while the ice dispenser calls for cubed and crushed ice.
Post the results.
Here are the breakdown diagrams and Replacement parts for Frigidaire FRS22ZRGW3 Frg(v3) / Refrigerator | AppliancePartsPros.com
Ice Maker Problems - Whirlpool (Refrigerator & Freezer Repair)
by tomkarl419 4/27/2022 5:37:11 AM(UTC)
Whirlpool Ice maker problems - no ice (Refrigerator & Freezer Repair)
by mphillips9im 7/17/2021 11:48:06 AM(UTC)
Whirlpool In Door Ice maker Problems (Dishwasher Repair)
by mphillips9im 7/17/2021 8:10:42 AM(UTC)
GE Ice Maker Problems (Refrigerator & Freezer Repair)
by GM1123 8/16/2015 6:55:23 PM(UTC)
GE Arctica Side-by-Side Ice Maker Problems (Refrigerator & Freezer Repair)
by coondog 7/22/2013 2:56:20 PM(UTC)
by K7527 6/11/2013 8:51:25 AM(UTC)
by ejg593 5/13/2013 10:23:12 AM(UTC)
I bet you get tired of seeing threads titled "Ice maker problems" (Refrigerator & Freezer Repair)
by highdensity10 1/22/2013 8:35:52 PM(UTC)
Ice maker problems (Refrigerator & Freezer Repair)
by vernjust 10/3/2012 6:19:32 AM(UTC)
Samsung Ice Maker problems (Refrigerator & Freezer Repair)
by bjc7 8/27/2011 6:15:48 AM(UTC)
by emenemenem 6/21/2011 11:53:28 PM(UTC)
Ice Maker problems again after replacing parts (Refrigerator & Freezer Repair)
by hooliek 6/3/2011 3:10:03 PM(UTC)
by luiV 5/25/2011 5:24:12 AM(UTC)
ice maker problems-help (Refrigerator & Freezer Repair)
by gramm 11/24/2010 9:32:45 PM(UTC)
ice maker problems (Refrigerator & Freezer Repair)
by pollyboone@roadrunner.com 7/20/2010 10:54:31 AM(UTC)
