Manopoli
#1 Posted : Tuesday, May 22, 2012 10:21:47 AM(UTC)
Manopoli
My oven does not turn off. I had to unplug it to get it to turn off when I plug it in same thing its still on. Now I'm not sure if it is the ignitor or the valve assembly, or am I completely wrong and its some thing else some one please help.
Thanks in advance
Simon / APP Team
#2 Posted : Tuesday, May 22, 2012 10:56:01 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Check if the oven thermostat knob is not stripped or broken inside. if the knob is OK than most likely there is a bad oven thermostat.
You can check it for continuity in off position. If there is continuity - replace the thermostat.Do not forget to unplug the range.
The thermostat Part number: WB20K8
Part number: WB20K8
The knob Part number: WB03K10142
Here are the breakdown diagrams and Replacement parts for General Electric JGBS23SEH5SS Gas range | AppliancePartsPros.com
Thank you. Post the results.
Simon.
Manopoli
#3 Posted : Tuesday, May 22, 2012 12:01:05 PM(UTC)
Manopoli
Thanks for the advice I'll check as the thermostat as soon as I get home .
Simon / APP Team
#4 Posted : Tuesday, May 22, 2012 12:47:22 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
GE gas oven not maintaining temperature after preheat completes (Oven Repair (including Ranges and Cooktops))
by Guest 12/2/2022 7:33:59 PM(UTC)
GE Gas Oven Control panel blank (Oven Repair (including Ranges and Cooktops))
by sjohnson1161 3/17/2021 6:23:41 PM(UTC)
GE GAS Oven will preheat but will not maintain set temp after reaching (Oven Repair (including Ranges and Cooktops))
by jblood98 3/11/2021 9:13:22 AM(UTC)
GE gas oven not heating (Oven Repair (including Ranges and Cooktops))
by 1alembic 4/4/2018 5:59:05 PM(UTC)
GE gas oven - broiler ignites, but not lower burner (Oven Repair (including Ranges and Cooktops))
by shortmort37 12/14/2017 6:11:01 PM(UTC)
GE Gas Oven, both burners won't light (Oven Repair (including Ranges and Cooktops))
by AlexelA 4/7/2016 9:54:33 AM(UTC)
Oven and Electronic clock stopped working on GE gas oven (Oven Repair (including Ranges and Cooktops))
by richfix 5/30/2015 6:44:26 PM(UTC)
GE Gas oven/broiler igniters glowing but gas not flowing. (burners OK) (Oven Repair (including Ranges and Cooktops))
by cbrodsky 12/10/2013 7:04:02 PM(UTC)
Burnt igniter wiring on old GE gas oven - why? (Oven Repair (including Ranges and Cooktops))
by akstens 1/4/2013 2:20:04 PM(UTC)
GE Gas Oven not heating up correctly (Oven Repair (including Ranges and Cooktops))
by ichengsd 6/19/2012 4:05:19 PM(UTC)
GE gas oven won't light -- igniter works (Oven Repair (including Ranges and Cooktops))
by markdraper 5/26/2011 10:37:41 AM(UTC)
GE gas oven not maintaining proper temp. (Oven Repair (including Ranges and Cooktops))
by bowflyman 1/5/2011 11:48:48 AM(UTC)
GE gas oven Broiler knob/switch malfunction (Oven Repair (including Ranges and Cooktops))
by 1consumer 7/27/2010 11:31:46 AM(UTC)
GE Gas Oven ignitor not glowing (Oven Repair (including Ranges and Cooktops))
by needhelp63 1/18/2010 6:46:49 AM(UTC)
by trumpets3u 12/16/2009 3:39:34 PM(UTC)
