My oven does not turn off. I had to unplug it to get it to turn off when I plug it in same thing its still on. Now I'm not sure if it is the ignitor or the valve assembly, or am I completely wrong and its some thing else some one please help.
Thanks in advance
Groups: APP Team
Hi. Check if the oven thermostat knob is not stripped or broken inside. if the knob is OK than most likely there is a bad oven thermostat. You can check it for continuity in off position. If there is continuity - replace the thermostat.Do not forget to unplug the range. The thermostat Part number: WB20K8
Thanks for the advice I'll check as the thermostat as soon as I get home .
Groups: APP Team
