cstefan
#1 Posted : Sunday, March 1, 2009 1:40:36 PM(UTC)
cstefan
Gas range approx. 15 years old. The display fades out so it can't be read. It has happened for many years. Previously you could tap on the area around the display & it would light up, but then faded again. Recently, tapping doesn't work. I think we need to replace something; what part/parts do we need?
kayakcrzy
#2 Posted : Sunday, March 1, 2009 4:31:21 PM(UTC)
kayakcrzy
You need to replace the clock control board. I would be able to give you a part #, but you are missing a letter and a # at the end. Tom
cstefan
#3 Posted : Sunday, March 1, 2009 4:55:37 PM(UTC)
cstefan
The model # from the stove is JGBP26GEN1WG
Hope this helps and thank you.
kayakcrzy
#4 Posted : Monday, March 2, 2009 4:13:50 AM(UTC)
kayakcrzy
I have checked 5 different parts sites for your model #, and none are coming up. The best thing you can do is to call GE, and see if they can help you get a part#. Tom ApplianceEducator.com
GE gas range oven won’t come on (Oven Repair (including Ranges and Cooktops))
by Guest 6/6/2021 3:02:24 PM(UTC)
F2 Error on GE Gas Range Model JGBP33SEH1SS (Oven Repair (including Ranges and Cooktops))
by dbevevino 6/15/2019 7:03:57 AM(UTC)
GE Gas Range Faulty Temp Readings and Slow to Heat (Oven Repair (including Ranges and Cooktops))
by yotimbo 2/9/2016 7:46:12 PM(UTC)
GE Gas range:XL44 - How to open sealed unit (Oven Repair (including Ranges and Cooktops))
by Jim Silvius 10/31/2012 12:02:04 PM(UTC)
Auto igniter not working on GE gas range (Oven Repair (including Ranges and Cooktops))
by saiprasad 6/28/2012 4:36:35 PM(UTC)
GE gas range (slide in) oven repair (Oven Repair (including Ranges and Cooktops))
by catinthehat 12/26/2011 10:13:16 AM(UTC)
GE Gas Range not holding temp (Oven Repair (including Ranges and Cooktops))
by Chance69 8/12/2011 9:24:40 AM(UTC)
GE Gas Range not holding temperature (Oven Repair (including Ranges and Cooktops))
by dfriend 2/23/2010 8:11:35 AM(UTC)
Burned insulation on igniter wires - GE gas range (Oven Repair (including Ranges and Cooktops))
by pbillow 1/31/2010 11:17:12 AM(UTC)
Maytage Gas Range - 2 Left Burners Won't Ignite - Have Spark (Oven Repair (including Ranges and Cooktops))
by boiler7904 9/28/2009 4:34:11 PM(UTC)
GE Gas Range Broiler will not shut off (Oven Repair (including Ranges and Cooktops))
by korybw 8/14/2009 8:21:55 AM(UTC)
Ge Gas Range Popped Circuit Breaker (Oven Repair (including Ranges and Cooktops))
by SFCHAMP97 6/5/2009 5:46:40 PM(UTC)
GE Gas Range diagnose ignite problem (Oven Repair (including Ranges and Cooktops))
by jonhunt 4/28/2009 9:37:12 AM(UTC)
by williamhaid 4/26/2009 2:10:48 PM(UTC)
GE gas range oven (Oven Repair (including Ranges and Cooktops))
by gdpifer 4/26/2009 7:53:06 AM(UTC)
