korybw
#1 Posted : Friday, August 14, 2009 8:21:55 AM(UTC)
korybw
The broiler on the range will not shut off unless the gas is shut off to the range. The ignitor stays lit unless the unit is unplugged.
#2 Posted : Friday, August 14, 2009 5:02:13 PM(UTC)
Most likely the problem is a bad oven thermostat. If you need the correct part number then post the complete model number of the range.
