korybw
#1 Posted : 16 years ago
korybw
The broiler on the range will not shut off unless the gas is shut off to the range. The ignitor stays lit unless the unit is unplugged.
#2 Posted : 16 years ago
Most likely the problem is a bad oven thermostat. If you need the correct part number then post the complete model number of the range.
