Hi everyone, I recently got an F2 error code on my GE gas range. Per a lot of online guidance, I replaced the temperature sensor. When I turned the power back on to the oven, I still got the F2 error code. Before spending a few hundred dollars on a GE technician, what other problems could cause the F2 error code? Any guidance is appreciated. Thanks.
