sstrueblue
#1 Posted : Sunday, December 18, 2011 5:54:52 PM(UTC)
sstrueblue
I have a Kenmore washer Elite series # 110.15962400. Is the top agitator supposed to lift off the bottom one by several inches ? i Know my dogs are shot but do i need to replace the cams too if so are they on this model long medium or short? Also sometimes the washer will not spin out the water completely when it has a full load of cloths but will spin fine with a smaller load . The tub seams balanced but will tip manually quite a bit from side to side but will always return to center. What wqould be the spinning out problem. Thank you for any help i can get
ApplianceJunk
#2 Posted : Sunday, December 18, 2011 6:01:37 PM(UTC)
ApplianceJunk
Are you sure about the model number? I can't find any information on it.
sstrueblue
#3 Posted : Sunday, December 18, 2011 6:07:43 PM(UTC)
sstrueblue
model # 110.15962400 is the correct Number sears kenmore
ApplianceJunk
#4 Posted : Sunday, December 18, 2011 6:12:38 PM(UTC)
ApplianceJunk
No, maybe the bolt that holds the agitator down to the shaft come loose.
Clutch could be slipping.
sstrueblue
#5 Posted : Sunday, December 18, 2011 6:16:54 PM(UTC)
sstrueblue
Thank you so much for your help. Now i know what to check out.
ApplianceJunk
#6 Posted : Sunday, December 18, 2011 6:19:52 PM(UTC)
ApplianceJunk
This video will show you about the clutch.
Washer Clutch Assembly (part #285785) - How To Replace - YouTube
Hope it helps.
Kenmore Washing Machine Model 417.29042992 (Washer Repair)
by jimylegg1 8/10/2020 5:39:45 PM(UTC)
Sears Kenmore Washing Machine 80 Series (Washer Repair)
by purecountry1127 11/4/2015 8:11:31 AM(UTC)
Kenmore washing machine not spinning without help (Washer Repair)
by narcsisuss 7/6/2015 5:54:17 AM(UTC)
Kenmore Washing Machine (Washer Repair)
by DStephens075@aol.com 6/19/2014 9:54:07 AM(UTC)
Kenmore washing machine, agitates while filling. (Washer Repair)
by Scott Eddy 6/2/2014 7:54:12 AM(UTC)
kenmore washing machine only fills (Washer Repair)
by stevieray2 6/7/2013 5:44:04 PM(UTC)
Kenmore washing machine (Washer Repair)
by MichelleM74 1/12/2013 11:51:42 AM(UTC)
kenmore washing machine top load (Washer Repair)
by bigfig 6/19/2012 4:56:24 AM(UTC)
Series 90 Kenmore washing machine NO COLD WATER (Washer Repair)
by Char H 5/10/2012 8:29:36 PM(UTC)
kenmore washing machine wont start (Washer Repair)
by buddy93 2/8/2012 2:20:20 PM(UTC)
Kenmore Washing Machine Timer Shaft (Washer Repair)
by GLion 6/1/2011 8:27:48 PM(UTC)
My Kenmore Washing Machine (Washer Repair)
by ignefeus 5/23/2011 6:49:06 AM(UTC)
kenmore washing machine (Washer Repair)
by ron walburn 2/16/2011 8:14:57 AM(UTC)
kenmore washing machine series 70 (Washer Repair)
by raineywillow 9/22/2010 5:26:49 PM(UTC)
Kenmore Washing machine (Washer Repair)
by bjhamrick 5/25/2010 8:37:48 PM(UTC)
