johnmk
#1 Posted : Tuesday, February 10, 2009 8:54:05 AM(UTC)
johnmk
Yesterday the dryer worked fine today it won't turn on. The light will turn on. No problems until today and it won't turn on. Any ideas?
magician59
#2 Posted : Tuesday, February 10, 2009 12:23:37 PM(UTC)
magician59
Gas, or electric?
Drags1998
#3 Posted : Tuesday, February 10, 2009 12:32:06 PM(UTC)
Drags1998
The first thing to check is the circut breaker panel in the house!!! If both breakers are OK, Pull the dryer out, remove the rear panel, and just above the dryer exhaust, you should see a small WHITE thermal fuse(with 2 blue wires) Unplug the 2 wires and connect them together. Tape them up so they can't short out, Plug the dryer back in and try it, if it works, get a new fuse and replace it!!!! DO NOT RUN THE DRYER WITHOUT THE FUSE!!!!!!!!! ITS A FIRE HAZZARD!!!!! Carefully check the vent system and the dryer to make sure its not overheating!!!!:)
LG Dryer won't turn on, but light on inside drum. (Dryer Repair)
by pshoebri 4/22/2018 8:12:26 AM(UTC)
Help!! GE Dryer won't turn on unless you spin it (Dryer Repair)
by Ruben C 12/6/2014 4:46:28 PM(UTC)
dryer won't turn on (Dryer Repair)
by pansie 8/15/2014 3:21:29 PM(UTC)
dryer won't turn on until it has cooled (Dryer Repair)
by Cam2ron2502 6/7/2013 1:43:31 PM(UTC)
Dryer won't turn on the motor or heating element (Dryer Repair)
by axnst1 3/13/2013 6:03:28 PM(UTC)
Dryer won't turn on. (Dryer Repair)
by generic 7/24/2012 5:16:50 PM(UTC)
dryer won't turn on, also light stays on with door closed (Dryer Repair)
by mazw 7/24/2012 4:17:25 PM(UTC)
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 6/22/2012 12:00:17 PM(UTC)
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 2/2/2012 9:30:47 AM(UTC)
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 12/15/2011 5:56:44 AM(UTC)
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 11/22/2011 1:31:36 PM(UTC)
Dryer Won't Turn On (Dryer Repair)
by maverickaf 8/30/2011 6:24:28 PM(UTC)
Dryer won't turn on (Dryer Repair)
by Lisa M 8/4/2011 6:34:07 AM(UTC)
by daveh59 7/4/2011 4:43:58 PM(UTC)
by momvilla 6/2/2011 2:14:44 PM(UTC)
