Blue
#1 Posted : 16 years ago
Blue
I have a Maytag Performa washer that makes a gear grinding noise during the wash cycle. It spins and drains fine. I replaced the agitator base and the noise is still there. What might be the problem?
tonyl
#2 Posted : 16 years ago
tonyl
Hi Blue,
I have the same exact problem on my Maytag Performa! One day the noise just started, everything seems to still work - I just haver this horrible noise like a gear is stripped or something. Only makes the noise when agitator is on, you can feel the vibration of the noise via the agitator. I took the agitator off expecting to see damage to the plastic splines - but nothing, they look OK. Did you ever figure out what the problem is?:confused:
#3 Posted : 16 years ago
You both might have a bad pump, just pull off the front panel, remove the belt and check the pump. If pump is ok, turn the trannt pulley in the agitate direction and check if you feal something binding in the tranny. If so, you need a new tranny.
Noisy washer spin (Washer Repair)
by TomHudson about a year ago
noisy washer, but difficult to pin down (Washer Repair)
by kScottk 2 years ago
noisy washer (Washer Repair)
by intimidatorwrath 9 years ago
by plumber123 11 years ago
Noisy Washer (Washer Repair)
by Nav5805 13 years ago
Noisy washer with water pump leak (Washer Repair)
by zippy617 14 years ago
Noisy washer (Washer Repair)
by jerry2083 15 years ago
by william clegg 15 years ago
very noisy washer at dryer cycle (Washer Repair)
Belarus awalle 16 years ago
very noisy washer (Washer Repair)
by Eric Nelson 16 years ago
by worthless52 16 years ago
Noisy washer (Dishwasher Repair)
by marsden4 17 years ago
by looz98 17 years ago
Noisy washer drain pump? (Washer Repair)
by mehullica 17 years ago
