william clegg
#1 Posted : Sunday, January 10, 2010 6:53:11 AM(UTC)
william clegg
Washer makes noises while it is washing. The noise only Last for a few minutes then it will stop. Then it will start again. THis goes on through the whole cycles of washing.
sidfink43
#2 Posted : Monday, January 11, 2010 10:58:33 AM(UTC)
sidfink43
It is almost impossible for us to diagnose a noise like you have described, because the main way we would do so is to take off the front of the machine and listen to. By determining its approximate location and the type of noise it is we could then make a semi-intelligent guess.
Anyway, I suggest you check out the pump so see if something is caught in there, and if not try to determine if the noise is from the transmission. That is the likely source, in which case since the machine is operating ok you can wait for it either to go away, which it probably will not, or for a part to fail in which case you can then tell what is wrong.
Sorry not to be more definitive, your problem just does not lend itself to a good diagnosis on a Forum like this.
Noisy washer spin (Washer Repair)
by TomHudson 10/22/2023 8:01:49 PM(UTC)
noisy washer, but difficult to pin down (Washer Repair)
by kScottk 4/16/2023 10:00:12 AM(UTC)
noisy washer (Washer Repair)
by intimidatorwrath 7/25/2016 6:11:33 PM(UTC)
by plumber123 11/3/2013 3:56:35 AM(UTC)
Noisy Washer (Washer Repair)
by Nav5805 11/9/2011 5:12:17 PM(UTC)
Noisy washer with water pump leak (Washer Repair)
by zippy617 1/23/2011 12:20:46 PM(UTC)
Noisy washer (Washer Repair)
by jerry2083 6/26/2010 2:13:19 PM(UTC)
by william clegg 1/12/2010 8:08:57 PM(UTC)
very noisy washer at dryer cycle (Washer Repair)
by awalle 6/28/2009 11:15:21 AM(UTC)
very noisy washer (Washer Repair)
by Eric Nelson 6/26/2009 12:43:03 PM(UTC)
by worthless52 2/25/2009 9:34:31 PM(UTC)
by Blue 2/5/2009 7:41:25 AM(UTC)
Noisy washer (Dishwasher Repair)
by marsden4 6/19/2008 9:26:15 AM(UTC)
by looz98 4/4/2008 7:58:07 AM(UTC)
Noisy washer drain pump? (Washer Repair)
by mehullica 10/28/2007 10:49:41 AM(UTC)
