ag1680
#1 Posted : Sunday, July 29, 2007 10:50:29 AM(UTC)
ag1680
A wire hanger got stuck right underneath the timer/selector knob. My wife pryed it out while the dryer was on. There was a short with a pop and flash. The dryer stopped working. Is there a fuse that needs to be replaced or is it the timer switch since that's where the hanger was stuck. Please help. Thank you
jdman
#2 Posted : Sunday, July 29, 2007 12:19:07 PM(UTC)
jdman
Check the breaker box. The breaker probably tripped. After you verify this, shut power off and open up console and check the contacts in the timer. I suspect that they are burnt. You can clean them up with a finger nail file. Good Luck
ag1680
#3 Posted : Sunday, July 29, 2007 7:57:48 PM(UTC)
ag1680
Thank you. It worked
LG Dryer won't turn on, but light on inside drum. (Dryer Repair)
by pshoebri 4/22/2018 8:12:26 AM(UTC)
Help!! GE Dryer won't turn on unless you spin it (Dryer Repair)
by Ruben C 12/6/2014 4:46:28 PM(UTC)
dryer won't turn on (Dryer Repair)
by pansie 8/15/2014 3:21:29 PM(UTC)
dryer won't turn on until it has cooled (Dryer Repair)
by Cam2ron2502 6/7/2013 1:43:31 PM(UTC)
Dryer won't turn on the motor or heating element (Dryer Repair)
by axnst1 3/13/2013 6:03:28 PM(UTC)
Dryer won't turn on. (Dryer Repair)
by generic 7/24/2012 5:16:50 PM(UTC)
dryer won't turn on, also light stays on with door closed (Dryer Repair)
by mazw 7/24/2012 4:17:25 PM(UTC)
Maytag dryer won't turn on. nothing lit except light when open door (Dryer Repair)
by eprunty 6/22/2012 12:00:17 PM(UTC)
Roper dryer won't turn on need some help (Dryer Repair)
by Robdob363 2/2/2012 9:30:47 AM(UTC)
dryer won't turn on..code F01 displayed (Dryer Repair)
by leamarie 12/15/2011 5:56:44 AM(UTC)
Admiral Dryer won't turn on. (Dryer Repair)
by TheoT 11/22/2011 1:31:36 PM(UTC)
Dryer Won't Turn On (Dryer Repair)
by maverickaf 8/30/2011 6:24:28 PM(UTC)
Dryer won't turn on (Dryer Repair)
by Lisa M 8/4/2011 6:34:07 AM(UTC)
by daveh59 7/4/2011 4:43:58 PM(UTC)
by momvilla 6/2/2011 2:14:44 PM(UTC)
