bluejohn
#1 Posted : Wednesday, August 10, 2011 7:46:07 AM(UTC)
bluejohn
My washer was reading out sud, then f35. I asked about this and was told by you folks that I needed a W10415587 water level switch. I ordered and received the switch and installed it. The unit now reads sud then f21, but never started to fill. The timer worked it's way down to 45 min and never started to fill. Before, if the timer got down to 48 min it would run through the cycle as normal. It would say sud and run through that cycle and at 49 min would read f35 or run normally. The part I was sent is a replacement for the origional and doesn't have metal contacts on the bottom where it plugs in. Where do I go from here?
thanks
john
bluejohn
#2 Posted : Wednesday, August 10, 2011 8:37:37 AM(UTC)
bluejohn
Please ignore, I had the part installed improperly. My son installed it and it works
thanks
john
Whirlpool duet steam washer intermittently turns off mid cycle. (Washer Repair)
by jlongo7000 11/19/2021 12:48:58 PM(UTC)
Whirlpool Duet Steam Model WFW9750WW01 (Washer Repair)
by wmsunder 5/9/2020 11:35:23 AM(UTC)
Whirlpool Duet Steam Error Codes (Dryer Repair)
by etamunupe 3/28/2020 5:09:00 AM(UTC)
Whirlpool Duet Steam blinking light and 3 beeps (Washer Repair)
by bigtwisty 11/23/2018 2:15:23 PM(UTC)
Whirlpool Duet Steam Washer - F20 Code (Washer Repair)
by ZMonet 8/15/2016 3:41:38 PM(UTC)
Whirlpool Duet Steam - F20 (Washer Repair)
by Dan.geddes 4/27/2015 6:36:00 PM(UTC)
Whirlpool Duet Steam control light on and washer won't start (Washer Repair)
by Marlene731 11/23/2014 9:41:55 PM(UTC)
whirlpool duet steam not draining (Washer Repair)
by VincentD 7/23/2014 2:18:18 PM(UTC)
Whirlpool Duet Steam Not Starting (Washer Repair)
by lstricker1974 5/29/2014 12:50:52 PM(UTC)
Whirlpool Duet Steam - new dispenser motor needed? (Washer Repair)
by Kbarrett 9/18/2013 12:48:27 PM(UTC)
Whirlpool Duet Steam Dryer had water in vent hose (Dryer Repair)
by dlhord 9/4/2012 4:06:59 PM(UTC)
whirlpool duet steam (Refrigerator & Freezer Repair)
by wapiwulo 5/24/2011 6:17:41 AM(UTC)
Whirlpool Duet Steam Washer F35 display (Washer Repair)
by lesandjimrpr 7/24/2010 11:38:48 AM(UTC)
Whirlpool Duet Steam (Dryer Repair)
by giget2000 10/3/2009 9:54:55 AM(UTC)
Whirlpool Duet Steam Washer Problem (Washer Repair)
by john.d.frank 8/21/2009 9:07:40 AM(UTC)
