The water and ice-making functions were working fine until we unplugged the fridge for kitchen reno. After plug-in, the water functions fine, but no ice is generated. The ice machine makes the right noises, but no ice is produced! Any switches I can find do nothing.
Suggestions?
Originally Posted by: emenemenem  The water and ice-making functions were working fine until we unplugged the fridge for kitchen reno. After plug-in, the water functions fine, but no ice is generated. The ice machine makes the right noises, but no ice is produced! Any switches I can find do nothing.
Suggestions? Emenem, It could take as long as 12 hours to start to produce proper ice cubes. The system has to flush all the air out before it works properly. Also check and make sure, none of the wires to the water inlet valve got knocked off or broken, during the move. Otherwise, start by repalcing the water inlet valve. :) :) :)
