os6352
#1 Posted : Friday, June 17, 2011 9:29:21 AM(UTC)
os6352
There was water leaking from my ice maker,now it won't fill with water. I checked fro continuity at test points V and L and there was none. I changed the module and rechecked continuity and still nothing. The ice maker has been out of the freezer for a day. I have 72 ohms at the heater element, I have no continuity at the thermostat. I have 120v between points L and N. I tryed to jump points T and H to turn The motor and nothing happened. Do I need to let the ice maker cycle for 24 hours and the thermostat close before i retest or is the something else going on.
#2 Posted : Friday, June 17, 2011 12:54:58 PM(UTC)
Quote:
...I checked fro continuity at test points V and L and there was none...
This result points to the possible problem with the water inlet valve.
Locate the water inlet valve on the back of the refrigerator. Swap the wires between the green and red solenoids. You probably have to use some extension wires because of different terminals size.
Depress the water release lever on the water dispenser for a few seconds and check if there is water in the ice maker. If there is no water and the water feeding tube into the ice maker is clear, replace the water inlet valve.
- The water inlet valve Part number: AP3160649
os6352
#3 Posted : Friday, June 17, 2011 2:30:04 PM(UTC)
os6352
I check that and there is no water, The ice maker also will not cycle when I jumper out test points T and H I have continuity there and i do have power everywhere else.
#4 Posted : Friday, June 17, 2011 4:21:38 PM(UTC)
Looks like the water valve has to be replaced.
Make sure the ice maker harness is connected properly and the "on-off" switch on the right side is on. Try to short the test points "T" & "H" one more time. Make sure the wire goes into the test points at least 1/2". If the ice maker would not start, the motor is bad. In such situation I would recommend to replace the whole ice maker. It makes repair more reliable.
- The ice maker Part number: AP3182733
GE PFE28RSHSS Door Ice Maker not filling (Refrigerator & Freezer Repair)
by msrkseger 3/15/2023 6:52:44 AM(UTC)
Ice Maker not filling with water. Water dispenser works. Kenmore Elite (Refrigerator & Freezer Repair)
by jeffrich12 1/21/2023 9:13:34 AM(UTC)
Ice maker not filling with water (Refrigerator & Freezer Repair)
by bdaddy711@aol.com 7/13/2016 6:00:46 PM(UTC)
KitchenAid Standalone Ice Maker Not Filling With Water After a Few Cycles (Refrigerator & Freezer Repair)
by jessep28 8/4/2014 2:58:30 PM(UTC)
Whirlpool Ice Maker not filling (Refrigerator & Freezer Repair)
by nathrr 4/11/2013 1:06:20 PM(UTC)
Whirlpool GSS26C5XXY00 ice maker not filling with water (Refrigerator & Freezer Repair)
by amain 11/5/2012 12:35:22 PM(UTC)
Ice Maker Not filling with water (Refrigerator & Freezer Repair)
by sooscreek 9/7/2012 12:24:44 PM(UTC)
Ice Maker not filling with water, dispenser works fine (Refrigerator & Freezer Repair)
by RobinM3 11/15/2011 8:57:12 AM(UTC)
GE Monogram Ice Maker not filling with water (Refrigerator & Freezer Repair)
by apfander 7/16/2011 10:23:07 AM(UTC)
Amana Ice Maker not filling with water (Refrigerator & Freezer Repair)
by dlstorch 5/6/2011 8:20:07 AM(UTC)
Ice maker not filling with H2O (Refrigerator & Freezer Repair)
by WayneA 3/22/2010 8:31:44 PM(UTC)
Kenmore Elite Ice Maker Not filling with H2O (Refrigerator & Freezer Repair)
by mnmavery 12/3/2009 1:21:01 PM(UTC)
Ice Maker not Filling with water (Refrigerator & Freezer Repair)
by rmoorhou 10/1/2009 4:17:41 PM(UTC)
Ice Maker Not Filling - Kenmore (Refrigerator & Freezer Repair)
by ezonana1 6/11/2009 6:09:20 AM(UTC)
by AlphaBob 5/12/2009 10:02:45 AM(UTC)
