21 Pages«<45678>»
arnieg
#51 Posted : 17 years ago
arnieg
I had the same problem with the same oven. The solution was to provide some insulation in the control wires. The procedure was developed by Charlie Popeck and is described at
The Dreaded "F7" Error - FixYa
eyecu1965dad
#52 Posted : 17 years ago
eyecu1965dad
Hi SMIMS,
In order to provide most accurate advise I need the complete model number of the range.
are model number is fgfl67dbd, it is a gas range oven. it goes into the f10 mode all the time. while we are trying to use the oven to cook.what do i need to do to fix this problem. any help would be greatly appreciated.
#53 Posted : 17 years ago
eyecu1965dad,
"F10" error code means runaway temperature. Check resistance of the oven temperature probe (aka temperature sensor). Normally it suppose to be about 1100 Ohms at the room temperature.
If the reading is wrong then replace the sensor.
If the reading is correct then replace the Electronic Oven Control (EOC).
- The part number for the oven temperature sensor is AP3704441
- The part number for the EOC is AP3778770
mabeck52
#54 Posted : 16 years ago
mabeck52
I have a Tappan range, error code F10 (not on the list). What does this mean? Easy to fix? Costly?
#55 Posted : 16 years ago
mabeck52,
What is the complete model number of the range?
eastex
#56 Posted : 16 years ago
eastex
Range, Maytag; MN CRE9600CCE;
Just replaced bottom oven element. It works fine, but will not turn off. Oven overheats and I am getting a F2 code and then an F7 code. Cancel button or oven stop button will not turn oven element off. Must unplug to turn off. Clock and other buttons as well as temp display seem to work OK. Oven stop button does turn temp display off.
HELP
shela
#57 Posted : 16 years ago
shela
:confused: i need to know how to fix a f1 err
#58 Posted : 16 years ago
Shela,
#59 Posted : 16 years ago
eastex,
The problem with your oven is a relay on the control board stuck closed. The control board has to be replaced.
- The part number for the control board is AP4008548
Here are the break down diagrams for the Maytag range Model CRE9600CCE
eastex
#60 Posted : 16 years ago
eastex
Thanks Gene. I suspected that was the problem, and chose to replace the range since it was 12 years old and probably not worth the cost of repair.
Thanks for the reply and the info.
Thermador Oven error codes (Oven Repair (including Ranges and Cooktops))
by jblake9000 10 years ago
Oven Error Codes & Won't Heat Fully (Oven Repair (including Ranges and Cooktops))
by davem68 12 years ago
Whirlpool oven error codes (Oven Repair (including Ranges and Cooktops))
by ajsml 13 years ago
by fred jacoby 13 years ago
by sigman 13 years ago
kENMORE OVEN ERROR CODES E3 FI (Oven Repair (including Ranges and Cooktops))
by chrisb361 13 years ago
Whirlpool Electic oven error codes (Oven Repair (including Ranges and Cooktops))
by fcarrelli 15 years ago
Oven error codes F3 and F2 (Oven Repair (including Ranges and Cooktops))
by emidgette 15 years ago
GE Oven error codes (Oven Repair (including Ranges and Cooktops))
by BobChurch 16 years ago
GE oven error codes (Oven Repair (including Ranges and Cooktops))
by bdeinhardt@aol.com 16 years ago
Whirlpool Double Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by alaucks 16 years ago
by cndybkr 17 years ago
Additional Oven Error Codes (Oven Repair (including Ranges and Cooktops))
by indydoug 17 years ago
21 Pages«<45678>»
