redsuspender
#1 Posted : Wednesday, April 9, 2008 5:15:30 PM(UTC)
redsuspender
I need to locate an exploded diagram and instructions to open the cabinet to clean lint from the inside of the dryer. Can anyone help?
#2 Posted : Thursday, April 10, 2008 12:42:17 PM(UTC)
I'm not familiar with this model. Maybe someone else on the forum can help you better.
Dryer Dad
#3 Posted : Thursday, September 25, 2008 2:49:45 PM(UTC)
Dryer Dad
Hi: I have the FD 8410 so it's probably similar.
1) disconnect the power
2) There are about 30 star head screws on the back. Most of them hold the back panel in place. However there are four or five that do not. You can tell them apart because the metal sections they hol appear to be underneath the main panel.
3) You may have to remove the cover over the electrical connection to remove the panel.
4) Remove the screws and electrical conenction cover.
5)There are two screws near the top of the back edge that hold the top on.
6) Remove those two and raise the lid ... about 2/3 of lid will come off .
7) Remove back panel and you can access most of the dust surfaces
Bosch Dryer No Power (Dryer Repair)
by kaigoss 11/28/2020 6:43:09 AM(UTC)
Bosch dryer - motor/drum not starting - what to check next? (Dryer Repair)
by noegruts 6/16/2015 8:10:31 AM(UTC)
Bosch dryer won't heat - tested usual suspects, what next? (Dryer Repair)
by sinoed 9/8/2013 7:00:44 PM(UTC)
Remove Bosch Dryer Front Panel (Dryer Repair)
by Rhatcher 1/13/2013 4:34:54 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Bosch Dryer - NO HEAT (Dryer Repair)
by Jake7706 11/14/2011 7:08:13 PM(UTC)
Replacing main switch on Bosch dryer (Dryer Repair)
by vlefebvre 5/9/2011 10:01:24 AM(UTC)
Bosch Dryer Help (Dryer Repair)
by Pugdog 2/12/2011 8:53:40 AM(UTC)
Bosch dryer stops, beeps, "Drying" and "End" lights on (Dryer Repair)
by endyem 11/23/2010 9:49:54 PM(UTC)
bosch dryer problem (Refrigerator & Freezer Repair)
by acm67 6/8/2010 11:43:54 AM(UTC)
Bosch Dryer won't heat (Dryer Repair)
by sam1 2/2/2010 7:50:45 AM(UTC)
bosch dryer wont start (Dryer Repair)
by racks54 7/23/2009 1:56:14 PM(UTC)
bosch dryer ,intermittant heat (Refrigerator & Freezer Repair)
by misterfixall 3/23/2009 11:46:47 AM(UTC)
bosch dryer will not start (Dryer Repair)
by tomok 1/22/2009 11:05:09 AM(UTC)
Bosch Dryer (Dryer Repair)
by MKrasne 9/3/2008 12:33:51 PM(UTC)
