I am having trouble with my dryer. Started out with a drum replacement problem. Go that fixed now having problems with the cycle times remaining at 0:00 instead of running the cycle time so the dryer wont start. When it was running I kept getting the E:01 error, however I have eliminated the lint tray and the duct work from being clogged. I have also replaced the sensor. Any suggestions on this mess!! Have tried everything.
Usually, the 000 is an open or shorted sensor. There are two sensors - one on the burner tube and one near the filter housing. If either one has a problem, you'll get the 000. If this first started after the drum was replaced, the harness may have accidentally been removed from the burner tube sensor.
Take the back panel off and check for a two-wire harness that's not connected to anything.
