MKrasne
#1 Posted : Wednesday, September 3, 2008 12:33:51 PM(UTC)
MKrasne
Although the facia panel was lit up, my dryer would not start when pushing the start button. A repairman replaced the control panel and it worked for a few minutes but then stopped. Again the facia panel is lit up, but the start button does not seem to work. Could it be something in the selector/display module? Any ideas? Thank you.
#2 Posted : Thursday, September 4, 2008 11:03:53 AM(UTC)
Did it show any error code? Did any light(s) have been flashing after the start button depressed?
Bosch Dryer No Power (Dryer Repair)
by kaigoss 11/28/2020 6:43:09 AM(UTC)
Bosch dryer - motor/drum not starting - what to check next? (Dryer Repair)
by noegruts 6/16/2015 8:10:31 AM(UTC)
Bosch dryer won't heat - tested usual suspects, what next? (Dryer Repair)
by sinoed 9/8/2013 7:00:44 PM(UTC)
Remove Bosch Dryer Front Panel (Dryer Repair)
by Rhatcher 1/13/2013 4:34:54 PM(UTC)
Bosch Dryer won't heat up (Dryer Repair)
by tericribb 3/18/2012 10:05:30 AM(UTC)
Bosch Dryer - NO HEAT (Dryer Repair)
by Jake7706 11/14/2011 7:08:13 PM(UTC)
Replacing main switch on Bosch dryer (Dryer Repair)
by vlefebvre 5/9/2011 10:01:24 AM(UTC)
Bosch Dryer Help (Dryer Repair)
by Pugdog 2/12/2011 8:53:40 AM(UTC)
Bosch dryer stops, beeps, "Drying" and "End" lights on (Dryer Repair)
by endyem 11/23/2010 9:49:54 PM(UTC)
bosch dryer problem (Refrigerator & Freezer Repair)
by acm67 6/8/2010 11:43:54 AM(UTC)
Bosch Dryer won't heat (Dryer Repair)
by sam1 2/2/2010 7:50:45 AM(UTC)
bosch dryer wont start (Dryer Repair)
by racks54 7/23/2009 1:56:14 PM(UTC)
bosch dryer ,intermittant heat (Refrigerator & Freezer Repair)
by misterfixall 3/23/2009 11:46:47 AM(UTC)
bosch dryer will not start (Dryer Repair)
by tomok 1/22/2009 11:05:09 AM(UTC)
Bosch Dryer (Dryer Repair)
by redsuspender 4/9/2008 5:15:30 PM(UTC)
