vlefebvre
#1 Posted : Monday, May 9, 2011 10:01:24 AM(UTC)
vlefebvre
The main switch on the front panel of my Bosch WTA3500 dryer no longer latches. I believe the main switch AP2805374 needs to be replaced. I can open the top of the dryer fine. But then, how do I open up the front panel and get access to the switch itself? Thanks.
rspaziani
#2 Posted : Tuesday, May 10, 2011 10:25:37 AM(UTC)
rspaziani
Remove the front control panel by releasing the series of clip tabs along the top edge. Push down on each one with a flat screwdriver and pry the panel off. Once the top edge is free, pull the bottom out...there are 5 posts along the bottom... pull straight out to remove panel. Don't pull too hard or you might damage the wires connecting the front control panel to the circuit board inside the dryer.
