endyem
#1 Posted : Tuesday, November 23, 2010 9:49:54 PM(UTC)
endyem
Our Bosch Axxis WTV76100US is about 1.5 years old and developed a strange problem.
The dryer will start, but then stop before the load is done, sound a bunch of beeps and flash the "Drying" and "Wrinkle Block/End" lights. The start/stop light is not illuminated.
Can someone help explain what this error means? I wasn't able to find a repair manual online.
Turning the dryer off, then on, clears this and it is usually possible to start it up normally.
bentenuto
#2 Posted : Friday, January 28, 2011 2:44:09 AM(UTC)
bentenuto
Hi
I have the same problem with my dryer. Did you ever find out the answer to your error code?
edselpdx
#3 Posted : Friday, October 19, 2012 3:46:49 PM(UTC)
edselpdx
Clean the moisture sensors as on P 20 of the manual https://d1vofmza27mmhi.cloudfron...-use-and-care-manual.pdf
fulker
#4 Posted : Saturday, December 31, 2016 2:08:51 PM(UTC)
fulker
Hi, I'm having the same problem. Our Bosch Axxis WTV76100US won't start, just continues to beep (3 sets of 4 beeps) and the "Drying" and "Wrinkle Block/End" LEDs are lit. I've cleaned everything including the moisture sensors (with white vinegar). I'm taking a closer look at the control panel right now, thinking I may have to replace. Did anyone have a solution?
