AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Bosch dryer stops, beeps, "Drying" and "End" lights on
Our Bosch Axxis WTV76100US is about 1.5 years old and developed a strange problem.
The dryer will start, but then stop before the load is done, sound a bunch of beeps and flash the "Drying" and "Wrinkle Block/End" lights. The start/stop light is not illuminated.
Can someone help explain what this error means? I wasn't able to find a repair manual online.
Turning the dryer off, then on, clears this and it is usually possible to start it up normally.
Hi I have the same problem with my dryer. Did you ever find out the answer to your error code?
Hi, I'm having the same problem. Our Bosch Axxis WTV76100US won't start, just continues to beep (3 sets of 4 beeps) and the "Drying" and "Wrinkle Block/End" LEDs are lit. I've cleaned everything including the moisture sensors (with white vinegar). I'm taking a closer look at the control panel right now, thinking I may have to replace. Did anyone have a solution?
Dryer Repair
