yjxl
#1 Posted : Tuesday, August 26, 2008 6:42:58 AM(UTC)
yjxl
the cycle signal buzzer comes on before the clothes are dry.the timer seems to be ok. could this be the cycle thermostat? if so where is it located? jim
libertyappl
#2 Posted : Tuesday, August 26, 2008 6:49:04 AM(UTC)
libertyappl
You probably should check the buzzer switch first, located in the control panel.
yjxl
#3 Posted : Tuesday, August 26, 2008 7:30:35 AM(UTC)
yjxl
the buzzer switch has been replaced.
#4 Posted : Tuesday, August 26, 2008 9:08:08 PM(UTC)
Hi Jim,
According to the "Use and Care guide" during the cool down portion of the Permanent Press cycle, the audible signal will sound intermittently.
If this is not the issue then the timer has to be replaced due to the buzzer is operated by the timer.
If the buzzer is not important to you then just turn it off.
In order to provide the right part number for the timer I need the serial number of the dryer.
GE Electric Clothes Dryer Shutting Down (Dryer Repair)
by bjohns610 4/28/2019 4:38:45 AM(UTC)
Electric clothes dryer (Dryer Repair)
by perkijl 5/30/2015 3:14:48 PM(UTC)
clothes dryer problem (Dryer Repair)
by jsullivan652 1/28/2014 1:20:49 AM(UTC)
Kenmore electric clothes dryer (Dryer Repair)
by saltydawg 7/21/2013 12:30:46 PM(UTC)
Loud squeaky clothes dryer (Dryer Repair)
by jeynafur 5/26/2013 7:27:41 AM(UTC)
Whirlpool Clothes Dryer Heat Shuts off (Dryer Repair)
by rglfinn 5/16/2012 3:39:59 AM(UTC)
Kenmore Clothes Dryer (Dryer Repair)
by pjm51 7/2/2011 10:02:29 AM(UTC)
amana clothes dryer (Dryer Repair)
by Vee Jay 5/13/2011 1:01:42 PM(UTC)
Clothes dryer not drying (Dryer Repair)
by wugwamp48 5/7/2011 10:22:49 AM(UTC)
replacing timer on clothes dryer (Dryer Repair)
by Al43110 8/8/2010 12:42:00 PM(UTC)
by evanwright 7/13/2010 3:35:37 PM(UTC)
Electric clothes dryer not running! (Dryer Repair)
by jjblum2002 2/2/2010 10:24:03 AM(UTC)
Frigidaire Clothes Dryer (Dryer Repair)
by Ristabile 12/28/2009 8:25:46 AM(UTC)
Maytag clothes dryer flame won't stay lit (Dryer Repair)
by Guyslienare 12/15/2009 10:29:58 AM(UTC)
Electric Clothes Dryer (Dryer Repair)
by aspenandy 11/23/2009 10:05:09 AM(UTC)
