Hello,
My dryer does not heat. I purchased parts from Appliancepartspros and replaced the sensor, ignitor and thermal fuse. I ensured there is a proper gas flow and the gas supply is clear. All electircal connections are snug and properly fitted. The dryer still does not heat. What could be the problem? Please advise.
Thank you, r/pjm
Thank you, r/pjm Have you read the Q&A's below the burner description here? WHIRLPOOL 279536 Burner, AP3094173 | AppliancePartsPros.com
