4 Pages<1234>
#11 Posted : Wednesday, December 15, 2010 1:32:14 PM(UTC)
Sounds like the problem is a bad control board (microcomputer). In order to access it you have to open the oven door and remove the screw on each side trim and remove the trims first.
- The control board Part number: AP3131994
cbo2010
#12 Posted : Thursday, December 16, 2010 4:54:05 AM(UTC)
cbo2010
Gene,
Thanks so much for the reply.
I just got a call from Kitchen Aid. Despite the unit no longer being under warranty, they said they would send someone out at no charge to do an evaluation of the unit based on safety concerns. They did mention they would not be covering the cost of repair, just the evaluation.
I had a couple questions for you. I assume Whirlpool and Kitchen Aid are one in the same? And, do you think the replacement of the control unit is something I can do knowing I am reasonably handle (but in no way an appliance repair professional). I assume no soldering is necessary?
Thanks again
#13 Posted : Thursday, December 16, 2010 2:08:22 PM(UTC)
Originally Posted by: cbo2010 Go to Quoted Post
...I just got a call from Kitchen Aid. Despite the unit no longer being under warranty, they said they would send someone out at no charge to do an evaluation of the unit based on safety concerns. They did mention they would not be covering the cost of repair, just the evaluation.
I had a couple questions for you. I assume Whirlpool and Kitchen Aid are one in the same? And, do you think the replacement of the control unit is something I can do knowing I am reasonably handle (but in no way an appliance repair professional). I assume no soldering is necessary?...
You are welcome.
It is good to hear that Kitchen Aid is willing to take care of such issues.
Kitchen Aid is a division of Whirlpool. It makes high end products.
Replacement of this part is basically removing screws and switching wires. Nothing complicated.
Keep us posted.
cbo2010
#14 Posted : Tuesday, December 21, 2010 7:59:10 AM(UTC)
cbo2010
Hi Gene,
We got our visit from the appliance repair person that KitchenAid sent out. His claim was that both the control board AND the touch panel should be replaced. I went into this thinking it was just the control board based on my observations I mentioned earlier so I pressed this guy to find out why he suspected also the touch panel. He gave a general answer from other units. He did not connect anything to it to test it. I suspect it is likely only the control board. Here is the catch. He gave prices...they are a bit higher than your price, but he claimed that KitchenAid is picking up the labor.
I would like to get your feel on things before I make a decision.
If I replace the control board myself it will be 1/2 the price. If I go with this guy it will be $724 with both parts including the taxes. Again, with KitchenAid (Whirlpool) picking up the labor..otherwise would have been around $850. If I replace the control board and find out I also need the touch panel, is that also relatively easy to install?
Thank you.
#15 Posted : Tuesday, December 21, 2010 1:48:40 PM(UTC)
With such diagnosis he is just protecting himself against mis diagnosis because there is very very small chance for the control panel to be bad as well.
The major question in this situation is: Does he guarantee his job? If he does, then for how long time?
P.S. You did not mention the color of the oven. Be advised that the black control panel is no longer available.
cbo2010
#16 Posted : Tuesday, December 21, 2010 3:08:52 PM(UTC)
cbo2010
Hi Gene,
Looks like the labor would be guaranteed for 90 days according to the paperwork.
The unit is white.
If the control panel is bad do you have a part number for that? How easy to install that one?
Thanks again.
#17 Posted : Wednesday, December 22, 2010 1:17:56 PM(UTC)
The labor charge is a very small part compare to the cost of parts. Do they guarantee the parts? What Kitchen Aid is going to do in case if this repair would not fix the problem? I do not think it's going to happen, just in case?
If you are going to use their service, I would recommend to ask these questions upfront.
The job to replace the control panel is very similar to replacing the microcomputer (control board). Mostly it is just screws and switching the wires.
- The white control panel Part number: AP3044378
cbo2010
#18 Posted : Wednesday, December 22, 2010 3:38:38 PM(UTC)
cbo2010
Gene,
Thank you. I will certainly take your advice and investigate the part guarantee question. If I have to guess right now it looks like the estimate paper indicates 90 days. Is that standard?
I agree what you are saying about Whirlpool. They are done. They won't assist further is my guess.
My thinking right now is that I will find the answers to the guarantee questions then may likely move forward to have the repair place do the work...but, only on the control board. The reason? The price for that with installation is within $10 if I buy it on this site (including shipping charges) and I would be doing the install. Sure, it's possible at that point the control panel may need to be replaced. If that happens I will order that from this site and do it myself. The difference in price there is about $60.
#19 Posted : Wednesday, December 22, 2010 4:03:35 PM(UTC)
You are right. Go for it.
Good luck and Merry Christmas!
P.S. Appliance Parts Pros guarantees all parts for a year.
cbo2010
#20 Posted : Sunday, January 9, 2011 9:15:09 AM(UTC)
cbo2010
Well, we had the repair place out here yesterday (1/2/2011) to replace the control board only. That seemed to go smoothly. He did mention that the control panel seemed ok. We turned on the power to the oven and things looked good. We preceded to turn on the convection oven and heated to 300 degrees. Then, shut it down by hitting the Lower Oven Cancel button. It responded. Some time later the oven cooled to a point that the fan stopped running (as it should). Repair dude departed. About 20 minutes later the oven fan came on. Seemed to be hot in the oven again indicating it came back on. Nothing special on the display (as in things looked normal when the oven is turned off).
At this point I'm at a loss. The repair guy felt the control panel seemed ok. We were not able to get in touch with him since by the time the issue came back it was Saturday afternoon. We did leave a message. Since then we have the oven powered off at the circuit breaker. I'm guessing these guys are going to want to replace the control panel.....but, I am frustrated. Seems the control board did not do the trick. And...what else could it realistically be??
Thank you.
Guest (5)
Kitchen Aid duel fuel oven won't turn off (Model: KDRS407VSS04) (Oven Repair (including Ranges and Cooktops))
by Guest 2/5/2024 6:06:45 PM(UTC)
oven won't turn off (Oven Repair (including Ranges and Cooktops))
by ssmith11 8/27/2012 3:39:26 PM(UTC)
Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by cap424646 5/9/2012 5:53:54 PM(UTC)
Whirlpool Double Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by jforeman 5/8/2012 7:09:34 PM(UTC)
Whirlpool Double Oven Won't Turn Off (Oven Repair (including Ranges and Cooktops))
by Bobmmm 2/7/2012 8:22:08 PM(UTC)
by oldschoolmc 1/4/2012 1:17:53 AM(UTC)
Kenmore oven won't turn off - recall (Oven Repair (including Ranges and Cooktops))
by genghiskhan 12/9/2011 11:02:28 AM(UTC)
by Debrab 6/5/2010 2:17:58 PM(UTC)
Kitchenaid Oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Jane D 4/14/2010 7:01:04 PM(UTC)
by buster42 12/18/2009 4:07:01 AM(UTC)
by camorasch 12/7/2009 2:31:40 PM(UTC)
Set-in oven won't turn off. (Oven Repair (including Ranges and Cooktops))
by tdtk42 11/6/2009 7:29:02 AM(UTC)
by danieltravagliante 7/26/2009 10:52:14 AM(UTC)
Whirlpool oven won't turn off (Oven Repair (including Ranges and Cooktops))
by Pat LaPorte 6/24/2009 8:45:36 PM(UTC)
by JDMACRAE 6/22/2009 6:30:20 PM(UTC)
4 Pages<1234>
