tenstan
#1 Posted : Monday, November 1, 2010 1:22:39 PM(UTC)
tenstan
The upper spray arm fell off. I have the arm and 2 plastic screw plug like things. How do I assemble it to replace it? Thanks
#2 Posted : Wednesday, November 3, 2010 2:23:15 AM(UTC)
Replacement parts for WHIRLPOOL KUDM01TJWH0 Undercounter Dishwasher | AppliancePartsPros.com
Un-clip the feed tube so you can pull it down a little.
Place a mounting pin (screw) in the mounting hole. I think it is the smaller one.
Place the spray arm on the feed tube, make sure the spray ho;les face down.
The other pin should then push into the other pin to hold the spray arm on.
Re-clip the feed tube.
You may need a new spray arm if the pins are broken.
It comes with the pins
Part number: AP3120022
tenstan
#3 Posted : Wednesday, November 3, 2010 8:32:02 AM(UTC)
tenstan
Thanks, It all fit together, I hope it will hold for several more washings. If not, I have the part number and will order one. Thanks! Jaine
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Kitchen Aid Dishwasher Upper Spray Arm (Dishwasher Repair)
by Guest 1/13/2022 12:58:02 PM(UTC)
whirlpool du850swpb2 spray arm (Dishwasher Repair)
by willyw 12/22/2021 12:31:52 PM(UTC)
Bosch 300 dishwasher - Middle spray arm only active for half-loads??? (Dishwasher Repair)
by Xcessiv 12/9/2020 5:58:19 AM(UTC)
Dishwasher Spray Arms Not Spinning / Not Enough Water [SOLVED] (Dishwasher Repair)
by MontyTWD 10/5/2020 8:05:23 PM(UTC)
KitchenAid KUDS30IXBLA Dishwasher Upper Spray Arms Not Spinning (Dishwasher Repair)
by navagator 8/24/2019 11:58:55 PM(UTC)
Bosch/Gaggeneau Low pressure from spray arms - tried everything (Dishwasher Repair)
by fixitboy 7/27/2019 10:50:29 PM(UTC)
Bosch dishwasher upper spray arm lost O-rings (Dishwasher Repair)
by Daniel J 2/10/2019 11:56:46 AM(UTC)
Frigidaire Gallery Dishwasher Lower Spray Arm Not Rotating (Dishwasher Repair)
by bhorv67 11/13/2018 9:28:24 AM(UTC)
upper spray arm screw broken (Dishwasher Repair)
by peabody 11/30/2016 10:47:12 AM(UTC)
Spray Arm Doesn't Turn - Probe Misaligned? (Dishwasher Repair)
by amc2012 4/15/2016 10:17:31 PM(UTC)
Center spray arm not spinning (Dishwasher Repair)
by Moleski 1/26/2016 9:28:31 AM(UTC)
Water Supply Tube & Spray arm dangling (Dishwasher Repair)
by yinger 9/13/2015 11:10:13 AM(UTC)
No pressure in spray arms (Dishwasher Repair)
by Doop007 9/4/2015 7:21:56 AM(UTC)
