spike27
#1 Posted : 15 years ago
spike27
Im getting 120v out of the two rectangular slots on the 4-wire receptacle. when I check for voltage on the red and black wire while its not
connected to the dryer I get 120v on each wire. But, when Im connected to
the dryer i get 120V on the red wire and no voltage the black. why? Dryer
doesn't work at all not even the drum light. can any one help?
Joe / APP Team
#2 Posted : 15 years ago
Joe / APP Team
Spike,
You need to varify where the power is in the outlet(is this new wiring or outlet?)
First (outlet configuration)
"D" shaped slot is ground (green or bare wire)
"L" shaped slot is neutral (White wire)
Right vertical slot is L1 (black wire)
Left vertical slot is L2 (Red wire).
From the L shaped slot to each vertical slot you should read 120 VAC.
From right to left vertical slot, you should read 240 VAC.
Were it me, I would also do the same checks from the "D" shaped slot, or pull the outlet and varify it is wired correctly.
Sounds like you've got a loose connection or crossed wires(same source) somewhere and you're loosing one of your hot legs, under a load, when power is being used by a component.
Good Luck,
spike27
#3 Posted : 15 years ago
spike27
I did all the voltage checks from neutral prong to vertical L and R 120v. and
from ground prong to vertical L and vertical R 120v. and vertical L to vertical R 240v. The dryer worked fine for two and a half years and a month ago it would just stop working like no power was going to it. I would check the breaker and it wouldn't be tripped. I would reset the breaker for the hell of it and it worked again for a week or so. Now, it stopped working for good. any
idea what happened? Thanks spike27
Joe / APP Team
#4 Posted : 15 years ago
Joe / APP Team
Spike,
Like I said in my previous post.
You're loosing a hot leg under a load, You've got a loose connection or a weak wire in your power supply wires to the outlet from the breaker box.
You're going to need an electrician to check the wiring and circuit.
Good Luck,
spike27
#5 Posted : 15 years ago
spike27
Thanks Joe. thanks for getting back to me.
Joe / APP Team
#6 Posted : 15 years ago
Joe / APP Team
Spike,
You're very welcome.
*** make sure they check your power supply "under Load" ***
Drop us a line when they're done.
amana cloth dryer ned4600yq1 dryer help heating (Dryer Repair)
by darmentle 3 years ago
Kenmore dryer help Elite HE3 (Dryer Repair)
by Guest 3 years ago
Samsung Dryer Help Needed (Dryer Repair)
by JMichael88 7 years ago
Whirlpool dryer help (Dryer Repair)
by mforesta 7 years ago
Dryer help please (Dryer Repair)
by Juliebolson 8 years ago
LOUD DRYER HELP! Video (Dryer Repair)
by kyle_couillard 8 years ago
LG Gas Dryer HELP (Dryer Repair)
by jdm99prelude 9 years ago
by Jenjudd2 10 years ago
by goatlady7 11 years ago
Frigidaire dryer help (Dryer Repair)
by pro69 11 years ago
by lola78 11 years ago
Estates Dryer HELP (Dryer Repair)
by cblakem02 11 years ago
GE Dryer help needed. (Dryer Repair)
by rad_rob 11 years ago
Maytage Bravos Quiet Series 300 Dryer Help (Dryer Repair)
by zfreeman 11 years ago
Electric Dryer Help Needed!!!! (Dryer Repair)
by redneckchevy9 11 years ago
